Persistent CEL 3 MAP Sensor and Falling Idle
Old Jul 20, 2007 | 07:28 AM
nikolai.'s Avatar
Default Persistent CEL 3 MAP Sensor and Falling Idle
I have an H22A that was recently installed. It is throwing a CEL 3 for MAP sensor.
When I clear the CEL, and then start the car, the engine fires up, the RPMs fall almost to 0, the CEL comes back and then normal idle speed resumes. There is a little fluctuation to the idle, but not much. I suspect that the stalling idle at startup is because the car is running rich from MAP malfunction.
I have replaced all of the vacuum caps and hoses to the IM.
I have tested for continuity on all 3 map sensor wires back to the ECU. The wiring is good.
I have tried 3 different MAP sensors.
The hose to my MAP was slightly loose so I replaced it with a smaller hose. Same results.
Yes I am resetting the ECU after every step.
Is it worth trying the fluctuating idle fixes, like cleaning out iacv, egr, fitv, and throttle plate? I don't see how this will fix my CEL.
Is my only other option to try to replace the ECU? I find it really hard to believe that everything else on the ECU is good except for the MAP Sensor input pin.
Thanks for any help.
Old Jul 20, 2007 | 07:45 AM
prelittlelude's Avatar
Default Re: Persistent CEL 3 MAP Sensor and Falling Idle (nikolai.)
if you traced all wires back to the ecu and resistance reads less than 1 ohm, and you have tried different maps, and yours possitive you have no vacume leak, then there are only 2 things it could be. bad pin where the connector at the cu touches the pin to the ecu, or a bad ecu. try getting your hands on another ecu to test with,
Old Jul 21, 2007 | 12:47 PM
nikolai.'s Avatar
Any other opinions? (though I value prelittlelude's quite a bit.)
Old Jul 22, 2007 | 04:00 PM
nikolai.'s Avatar
I'm almost 100% its the ECU. I went through the troubleshooting procedure in the Helm's one more time today. The middle wire is the signal. Apparently when the sensor is removed and the ECU is on, that wire should read 5V coming from the ECU. We'll I'm only getting like 25-30mV. The sensor lead does measure around 3V at idle when everything is connected, which is roughly 20inches of vacuum. I'm going to replace the ECU and see if it fixes the problem.
Old Jul 29, 2007 | 03:03 PM
nikolai.'s Avatar
Replaced the ECU today.
Still getting CEL 3, bouncing idle and running rich. Looking for suggestions. My next step is to go over everything one more time. Then I'm going to light the car on fire.
Old Jul 30, 2007 | 10:18 AM
nikolai.'s Avatar
up
Old Jul 30, 2007 | 10:42 AM
Eddiebx's Avatar
check and make sure the pins in the connector at the ecu are not loose, i had one that loosened up on me, and gave me random fuel injector problems because it was loosing contact randomly.
Old Aug 12, 2007 | 01:37 PM
b16a4's Avatar
Default Re: (Eddiebx)
did you figure it out?
Old Aug 13, 2007 | 12:55 PM
nikolai.'s Avatar
Eddiebx was right. I just figured it out yesterday. The MAP pin into the ecu was loose. I actually tried extracting it and it was jammed in there for some reason. I'm going to get a new connector from a junkyard and repin it.
I'm 100% thats what the problem has been the whole time though. I removed the top panel from my ecu and checked continuity from the lead inside the ecu case to just on the other side of the connector. All the other leads were fine except for that one.
Old Aug 15, 2007 | 12:52 PM
Default Re: (nikolai.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. &raquo;</TD></TR><TR><TD CLASS="quote">Eddiebx was right. I just figured it out yesterday. The MAP pin into the ecu was loose. I actually tried extracting it and it was jammed in there for some reason. I'm going to get a new connector from a junkyard and repin it.
i said this would be one of 2 things, bad pin or bad ecu. I typed to fast and meant to tell you to check for a bad connection or loose pin, for some reason i meant to say connector in my fisrt post and it came out at cu? glad you found the problem
Old Aug 15, 2007 | 06:02 PM
nikolai.'s Avatar
Default Re: (prelittlelude)
oops. just noticed that. wish i had checked this first.
Old Aug 17, 2007 | 01:41 AM
da9blk1's Avatar
it worked?
Old Aug 17, 2007 | 12:53 PM
nikolai.'s Avatar
I actually haven't replaced the connector yet, but I know this is the problem.
Old Aug 18, 2007 | 02:07 PM
nikolai.'s Avatar
I ogt a new connector and changed that one pin and the code went away. I still have an eratic idle, despite everything else that was done.
Old Aug 19, 2007 | 08:44 AM
da9blk1's Avatar
thanks i got the same problem. im just gonna plug in my apexi Neo again and that does the trick haha thanks
Old Aug 20, 2007 | 06:11 AM
h22a1_julien's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. &raquo;</TD></TR><TR><TD CLASS="quote">I ogt a new connector and changed that one pin and the code went away. I still have an eratic idle, despite everything else that was done. </TD></TR></TABLE>
check your EGR...and TPS
Old Aug 20, 2007 | 06:50 PM
nikolai.'s Avatar
cleaned out the egr already when i cleaned out my iacv and fitv. i also have the egr vac port capped off. when i connected it to the IM the car ran like crap.
i actually am thinking about the tps now. i sprayed all my vacuum caps, hoses and my IM gasket with carb cleaner to check for leaks and notices that there is some air getting sucked in around my TPS.
I also tried unplugging my iacv. The idle dropped to normal but was still bouncing.
Old Aug 22, 2007 | 10:33 PM
da9blk1's Avatar
damn plugged the neo in and aint doing **** how much was the connecter did you get it 4m the junkyard?
Old Aug 23, 2007 | 03:47 AM
nikolai.'s Avatar
i got all three connectors and a door handle fro like $20. Plus I had to spend $20 on some boots to trudge through 8" of mud.
Old Aug 23, 2007 | 11:48 AM
nikolai.'s Avatar
i actually am thinking about the tps now. i sprayed all my vacuum caps, hoses and my IM gasket with carb cleaner to check for leaks and notices that there is some air getting sucked in around my TPS. </TD></TR></TABLE>
Wasn't the TPS leak. Sealed it up well with some Hondabond. Tried screwing my FITV in some more (it was all the way out). Same results. All I can think is that there is a vacuum leak somewhere that I cant find. It may be leaking from the IAB vacuum switch/tank thats under the IM. I am basically going to read the entire section on the Idle Air Control system in my Helms and see if I've missed anything, unless anyone can give anymore help.
Key point here: It doesn't act like your usual FITV issue because the idle still bounces when the car is warmed up. Though the bouncing is not as bad when warm.
Old Aug 23, 2007 | 02:21 PM
da9blk1's Avatar
would the map sensor cause mass fuel consumption at all?
Old Aug 24, 2007 | 03:48 AM
nikolai.'s Avatar
yes. if you aren't getting a map signal (or the wrong signal for that matter) you ecu will run very rich off its fuel tables, which are usually adjusted based on map readings.
Old Aug 24, 2007 | 07:09 AM
mgags7's Avatar
just fyi, the ecu defaults to the base fuel maps when the map isn't working, it is rich as hell, rough as hell, and won't rev over 3000rpm.
Old Aug 24, 2007 | 03:25 PM
da9blk1's Avatar
Default Re: (mgags7)
mine revs but i noticed gas consumption
and my car is running rich
smells like pure gas!@rgh@!
Old Aug 24, 2007 | 05:25 PM
nikolai.'s Avatar
fixed everything this evening. Removed the FITV again and screwed it all the way in. Set the idle adjustment screw according to the steps in Helms. Idle was still bouncing between 600-700 at idle warmed up. Bleed the coolant for what must have been 45minutes to an hour. Decided to changed the plugs. They were completely fouled from running with no MAP (duh..). Changing the plugs took care of the remaining bouncing idle. I think it was a culmination of several issues.
The one thing that I still don't understand is that I still have a vacuum on my FITV port in the throttle body even when the car is completely warmed up. I can only assume that I still have air in the system that need to be bled out OR the FITV is indeed bad.
