starter problem... I think?
Old Jul 21, 2007 | 03:22 PM
Prudz_lude's Avatar
Default starter problem... I think?
I think my starter is taking a dump on me finally. How do you know? My car sometimes does not start up for a minute or two. Other times it starts up fine. When it finally starts up it runs great so i assume its not the alternator. When it does not start up it does not crank over. Do these sound like the symptoms of a starter failing?
Old Jul 21, 2007 | 03:27 PM
xxmastermindxx's Avatar
Default Re: starter problem... I think? (Prudz_lude)
probably. try taking it out and take it to an auto part store near you, they should be able to test it for you.
Old Jul 21, 2007 | 05:33 PM
mafia's Avatar
Default Re: starter problem... I think? (xxmastermindxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">probably. try taking it out and take it to an auto part store near you, they should be able to test it for you.</TD></TR></TABLE>
I did that once, they will tell you
Old Jul 21, 2007 | 05:55 PM
prelude_93vtec's Avatar
when that happened to me, it was my main fuel relay. it started sometimes and didnt others until it just gave up all together. try checking that
Old Jul 21, 2007 | 06:06 PM
street_ride14's Avatar
Default Re: starter problem... I think? (prelude_93vtec)
Check your grounds, poor contact.
Old Jul 22, 2007 | 01:52 PM
4WSBeast's Avatar
Check the connections on the starter. If there fine make sure your battery terminals are tight. If that doesn't work then pull the starter out and have it checked but your local parts shop.
Old Jul 22, 2007 | 06:37 PM
Prudz_lude's Avatar
Default Re: starter problem... I think? (4WSBeast)
the battery terminals are so tight i cant take them off. All the grounds are good as well. Its a brand new battery as well. Once its running its fine. The problem is starting to get worse. It starts less and less often and i am starting to worry it just won't start soon. I am going to pick up a new starter tomorrow because its got 130miles on it so its pretty old. Fuel relay, how expensive is that to fix?
Old Jul 22, 2007 | 07:16 PM
InvaderTrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">when that happened to me, it was my main fuel relay. it started sometimes and didnt others until it just gave up all together. try checking that</TD></TR></TABLE>
Main relay will keep it from starting, not from turning over. Could be:
starter
ground wire on starter
starter contacts
The contacts are replaceable. Honda doesn't sell a kit for it, but Toyota does. It's $10, and takes a little over an hour if you've never done it before. I'd do that before dumping money on a whole new starter
Old Jul 23, 2007 | 06:31 AM
Prudz_lude's Avatar
Default Re: starter problem... I think? (InvaderTrax)
Are the starter contacts those wires running off the starter? if so it's them. I noticed that when i unplugged them and then replugged them it works everytime. After driving on bumpy roads if i turn the car off and try to start it up again it does not work. I pop the hood and push the wires together again and it starts up fine. Old wires i guess.
Old Jul 23, 2007 | 05:54 PM
Nope, that's the ground wire. The contacts are inside the starter
norbertocartage
Feb 25, 2013 07:30 AM
TheCrimsonGhost666
Feb 28, 2010 06:53 AM
uneek4dr
Honda Civic (2001 - 2005)
Dec 2, 2007 09:12 AM
burnitdown
Oct 15, 2007 10:42 PM
tchen415
Sep 12, 2006 04:55 PM
