How to test a relay?
Old Jul 22, 2007 | 04:16 PM
vinuneuro's Avatar
Default How to test a relay?
I hate electrical problems and they hate me. What does this mean?
Old Jul 22, 2007 | 04:22 PM
Hawkze_2.3's Avatar
Default Re: How to test a relay? (vinuneuro)
Basically it means that when power is flowing through the relay (from 3 to 4), then it should activate the other path inside the relay (from 1 to 2). Run power through 3 & 4 and then hook up 1 & 2 terminals to power and test them for flow with a multimeter.
Old Jul 22, 2007 | 04:37 PM
vinuneuro's Avatar
Default Re: How to test a relay? (Hawkze_2.3)
So use a 9v battery to apply power?
Old Jul 22, 2007 | 04:39 PM
Hawkze_2.3's Avatar
Yeah, that should work as far as I know...
Old Jul 22, 2007 | 04:43 PM
vinuneuro's Avatar
This is a damn stoopid q, but what setting do i use on the multimeter?
Old Jul 22, 2007 | 04:52 PM
Hawkze_2.3's Avatar
There should be options that say something like 2v, 20v, 200v, etc... 2v gives you readings like 1.435v, 20v setting gives you like 14.35v for example and 200 is like 143.5v.
Anyhow, use the 20v or whatever your mutimeter has that will include the power of the battery you use.
Old Jul 22, 2007 | 05:02 PM
xxmastermindxx's Avatar
don't know if you already figured it out, but the way i test them would be to set your meter to continuity, basically its an ohm reading of resistance. your meter will probably have a setting that beeps when there is continuity.
in this case with this particular relay, set your meter to continuity, test pins 1 and 2, and you should get no reading, basically an open circuit. now power the relay at pins 3 and 4, yes your 9v should work fine, and then test pins 1 and 2 again. you should now have continuity, if the relay works fine.
it's a lot easier than the two paragraphs i wrote
Old Jul 22, 2007 | 05:09 PM
vinuneuro's Avatar
Default Re: How to test a relay? (xxmastermindxx)
thanks guys!
https://honda-tech.com/zerothread?id=2049301
JustCant5topMe
Mar 27, 2013 07:10 PM
civicpark81
Feb 29, 2008 07:10 PM
CrazyModGSR
Audio / Security / Video
Oct 29, 2004 11:32 AM
T25 civic
Nov 18, 2002 07:23 PM
