strut replacement
Old Aug 1, 2007 | 04:11 PM
billyinse's Avatar
Default strut replacement
i have a 97 lude witha bad strut how do i replace it? i searched but didnt find anything
Old Aug 1, 2007 | 04:17 PM
m00nr0ck Si's Avatar
Default Re: strut replacement (billyinse)
-Jack up car
-remove wheel
-remove lower strut fork to lca bolt
-remove strut pinch bolt
-loosen strut tower nuts
-remove brake line bolts
-remove strut and spring assembly
-compress spring
-remove top hat nut
-remove old strut and replace in reverse order
Old Aug 1, 2007 | 05:19 PM
hamadiscool's Avatar
Default Re: strut replacement (m00nr0ck Si)
I wrote a how-to on preludepower for installing kyb shocks and ground cover coilovers. This should help you get ur strut replaced too!
http://preludepower.com/forums...58649
Goodluck!
Old Aug 2, 2007 | 12:08 PM
billyinse's Avatar
Default Re: strut replacement (hamadiscool)
thanks guys
Old Aug 19, 2007 | 08:27 PM
LSTEG96's Avatar
you dont sell a car that has "bad valves" when the entire motor is trashed.
whoever looked at this car and told you it was the valves should be swiftly punched in the *****.
Old Aug 19, 2007 | 09:13 PM
dagle's Avatar
Default Re: strut replacement (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">you dont sell a car that has "bad valves" when the entire motor is trashed.
whoever looked at this car and told you it was the valves should be swiftly punched in the *****. </TD></TR></TABLE>
im lost...
Old Aug 21, 2007 | 09:11 PM
LSTEG96's Avatar
was told "bad valves" and recieved totally trashed motor
Old Aug 21, 2007 | 11:07 PM
Hawkze_2.3's Avatar
Default Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">was told "bad valves" and recieved totally trashed motor</TD></TR></TABLE>
Are you lost?
Old Aug 21, 2007 | 11:31 PM
dagle's Avatar
Default Re: (Hawkze_2.3)
thats exactly what i was thinking... struts = suspension... this = prelude forum. and TEGGER is telling us about BAD VALVES and a trashed motor..
im forced to pull the JDMWTF? card. the guys in the integra forums are trying to invade, time to install a nice machine gun setup since i dont have fogs anyways.
Old Aug 22, 2007 | 12:41 PM
LSTEG96's Avatar
Default Re: (dagle)
wow guys. lets tie this together... the prelude hes talking about is from MN... the integra i was talking about is from SC.... catch my drift?
Old Aug 22, 2007 | 01:35 PM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">wow guys. lets tie this together... the prelude hes talking about is from MN... the integra i was talking about is from SC.... catch my drift?</TD></TR></TABLE>
Let me guess, you bought his old Integra LS with bent valves and he didn't tell you. According to his sig. he sold an LS Turbo'd Integra, and according to your sig. you have a blown LS motor up for sale
Old Aug 22, 2007 | 01:45 PM
dagle's Avatar
Default Re: (prelude1897)
i woulda never put that one together
Old Aug 22, 2007 | 06:08 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">
Let me guess, you bought his old Integra LS with bent valves and he didn't tell you. According to his sig. he sold an LS Turbo'd Integra, and according to your sig. you have a blown LS motor up for sale</TD></TR></TABLE>
wow, the h-t sleuth
Old Sep 1, 2007 | 11:38 AM
h22a4lude's Avatar
close, the motor in the sig is an anchor and did not come out of my teg. should be up and running in hours.
navcc
Apr 8, 2011 03:10 PM
spooky187
Acura TL, RL & ZDX
13
Jun 27, 2010 04:58 PM
four o two
Jan 6, 2006 05:55 PM
nc-rsx-s
Aug 17, 2002 03:51 PM
