idle issues
Old Jul 31, 2007 | 08:57 PM
invasian_boy's Avatar
Default idle issues
i was wondering if anyone had the same problem as me. i have a 98 prelude and for some reason my car has trouble idling or something esp on hot days my car dies all the time when i idle, on cooler days it dosnt seem to have alot of problems dealing with the idle. also when i drive for a long time and the motor is hot to operating temp, if i turn off the car for like 5 mins and come back n start it up my idle goes down real low and almost dies? any help??? thanks
Old Aug 1, 2007 | 03:39 AM
carnot's Avatar
Default Re: idle issues (invasian_boy)
IACV? idle screw? is your car modified or completely stock?
Old Aug 1, 2007 | 04:53 AM
gogunkergorilla's Avatar
could be a number of things. poor connectivity in your main relay closely fits those symptoms. it's more noticeable in hot weather and usually causes starting problems, low idling and stalling. there are "how to's" all over the internet to repair it yourself. just do a search.
Old Aug 2, 2007 | 12:07 PM
Default Re: idle issues (carnot)
my car just has normal boltons like i/h/e
Old Aug 2, 2007 | 07:07 PM
M2B4's Avatar
good luck im battling a idle similar to that. when car is under no load after driving (pushing in pedal at stop light) idle will bounce from ~100 rmps to ~600 rpms died once. ive cleaned iacv, fitv, egr, new plugs, new wires, new rotor, checked over vacuums, new ect. nada nothings fixed. i just got done cleaned iacv again and using a silicon sealer to make a new gasket. im hoping it wasnt sealing fully and had a leak its curing right now ill let ya know if that helps.
Old Aug 2, 2007 | 07:25 PM
Default Re: idle issues (M2B4)
it's also a sign of worn thrust bearings.
Old Aug 28, 2007 | 06:08 PM
b16a4's Avatar
lemme know if you fix your problem
i have same probem
b18cisbetter
Dec 8, 2009 06:04 AM
ddubtoille
Aug 13, 2008 02:39 PM
tylerdurden
Apr 11, 2003 05:53 PM
raene
Nov 7, 2002 08:21 PM
