AEM EMS base map 00 prelude
Old Aug 4, 2007 | 09:07 AM
g_dub's Avatar
Default AEM EMS base map 00 prelude
Ok I am really having a problem finding a base map for a mostly stock 2000 prelude 5sp non-sh. I have AEM EMS 1020 and the map that comes with it does not work. I have searched all the forums including hondatech's and AEM's and have not found what I needed. Please help.
aem ca intake
dc sports header
tanabe racing medalion catback
walbro fuel pump
zex dry kit
Old Aug 4, 2007 | 09:18 AM
InvaderTrax's Avatar
You don't even need an EMS with that setup...
Old Aug 4, 2007 | 09:24 AM
g_dub's Avatar
Default Re: (InvaderTrax)
Understandably, but that doesn't help. I want to use it now to eliminate my redline and top speed governer and to lower my Vtec engagement point and to start and idle. And so I can install my 550 injectors.
fastlude69's Avatar
he needs it for the n2o i guess for timing adjustment also your redline limited their is no top speed limit on your car. ems is alot of money to spend epically when your running a dry shot. i would've personally just ran crome but to each his one.
Old Aug 4, 2007 | 09:27 AM
fastlude69's Avatar
also your redline there for a reason espically with a stock head and stock valve train with nitrous.
Old Aug 4, 2007 | 09:28 AM
g_dub's Avatar
Default Re: (fastlude69)
Well that and I have a turbo setup sitting around waiting for ems to work right so when the turbo is installed it will tune a little easier.
Old Aug 4, 2007 | 09:29 AM
g_dub's Avatar
I understand why the redline is there but I don't want to hit the rev limiter running the nitrous, I will still shift @7900 like usual, I just don't want to go lean and detonate.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlude69 &raquo;</TD></TR><TR><TD CLASS="quote">also your redline there for a reason espically with a stock head and stock valve train with nitrous.</TD></TR></TABLE>
Old Aug 4, 2007 | 09:38 AM
fastlude69's Avatar
what does not work about the map that came with your ems.
Old Aug 4, 2007 | 09:42 AM
g_dub's Avatar
It will start but only if you have the throttle at like 50% and it runs really rough. If you let off the gas it stalls instantly. BUMP I need a stock base map that works good.
Old Aug 4, 2007 | 09:48 AM
fastlude69's Avatar
do you have the wideband with it and did you make sure all the parameters are set correctly
Old Aug 4, 2007 | 10:02 AM
g_dub's Avatar
yes
Old Aug 4, 2007 | 10:11 AM
JonGP4's Avatar
Have you tried the AEM forums? Lots of good base maps are posted up there.
Old Aug 4, 2007 | 10:24 AM
98vtec's Avatar
moderator emeritus
Default Re: (g_dub)
if you dont know how to operate the program, find someone who does. People take classes to learn how to fully use this ems to its potential. These maps are not the kind you use to start up and think the car is going to drive normal.
Either learn how to use it or pay someone who already knows how.
Old Aug 4, 2007 | 10:37 AM
Rosko's Avatar
Default Re: (98vtec)
you probably just need to scale the fuel map for the 550cc injectors you are using, and then some. the ems isn't one to be messed around with, the base maps are designed to get the car running only, not driveable and certainly not raceable.
Old Aug 6, 2007 | 02:54 PM
g_dub's Avatar
Default Re: AEM EMS base map 00 prelude (g_dub)
ok I understand everything your all saying but I am looking for a map that has already been tuned and calibrated to run a stock prelude. They have them for civics on their forums and they have them for accords on their forum but here on the prelude forum we have jack sh--. There has to be someone that has a stock prelude tuned with aem ems, and I am trying to find them. I dont want one just to start it, I want want that is tuned. Thx for all the help though.
Old Aug 6, 2007 | 03:05 PM
Speedra500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">you probably just need to scale the fuel map for the 550cc injectors you are using, and then some. </TD></TR></TABLE>
did you already try this?
Old Aug 6, 2007 | 03:14 PM
g_dub's Avatar
Default Re: AEM EMS base map 00 prelude (Speedra500)
those injectors are not in yet because they have nothing to run them...k.
I need a tuned map for a stock prelude. A TUNED MAP FOR A STOCK PRELUDE.
Old Aug 6, 2007 | 03:38 PM
DCxMagus's Avatar
odds are you aren't going to find one very easily man, thats just the truth of it.
civic and accords are way more popular to tune then preludes...
why don't you just take a stock H22 accord map and use that?
Old Aug 6, 2007 | 06:30 PM
98vtec's Avatar
moderator emeritus
talk to AEM
Old Aug 6, 2007 | 06:37 PM
gogunkergorilla's Avatar
Default Re: AEM EMS base map 00 prelude (98vtec)
read the ebooks, then learn from someone who knows it...that software is so complex that its going to take more than reading a couple of posts to get you up and running.
Old Aug 7, 2007 | 09:36 AM
cparreno's Avatar
Unfortunately noone likes to pay money to tune a stock car so there wont be much out there for it. since it fires up and you have a wideband, just tune the air fuel so its driveable and take it to your tuner.
then post your calibration so it helps others in the future. If you need any more help let me know.
1990hondacrx
Engine Management and Tuning
10
Oct 23, 2009 10:33 AM
Gdub00lude
Aug 4, 2007 10:12 AM
shermanyang
Mar 10, 2005 07:24 PM
Prelude Vtec 23
Aug 1, 2003 12:54 PM
Xav H22EG8
Apr 22, 2002 09:29 PM
