AC Compressor Question
Old Jul 27, 2007 | 01:32 PM
ConanDan's Avatar
Default AC Compressor Question
First, I inquired about a Compressor a while back from a guy here, and I cant remember his name. He had a few of them. If you read this, please contact me.
Second, if I want to replace my AC compressor, how involved is the procedure? Do I need anything other than another compressor? Any gaskets? Ill have to refill the refrigerant right?
Old Jul 27, 2007 | 06:29 PM
PrettyLude's Avatar
you will need to change the dryer, pull a vaccuum and recharge
Old Jul 27, 2007 | 11:24 PM
M2B4's Avatar
Default Re: (PrettyLude)
not very difficult take belt off 2 r 3 bolts cant remember 2 bolts @ dryer (getting to it is kinda crappy) if i remember right. put new comp and dryer on bolt down put belt back on recharge. *remember dont let the refrigerant into the air its against the law *
Old Jul 28, 2007 | 08:21 AM
M@'s Avatar
M@
Default Re: (M2B4)
Also its recommenced to replace the 0-rings. It would be nice if you could borrow the tool that is used to adjust the tension on the belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote"> 2 bolts @ dryer (getting to it is kinda crappy) if i remember right. | *</TD></TR></TABLE>
Yes then I did it I had to take to front bumper and passenger side headlight off. If you do that then its pretty easy. If your compressor grenaded it might not be a bad idea to get someone to flush it for you incase you have a valve clogged or something.
Old Jul 28, 2007 | 01:26 PM
ConanDan's Avatar
Default Re: (M@)
The compressor is just making noise, and that means that the bearing on the inside is going out. Im looking to replace it, and I want to get the parts for my mechanic, rather than him buy the parts.
Old Jul 29, 2007 | 06:21 PM
M@'s Avatar
M@
Default Re: (ConanDan)
I'm not sure you will need to replace the dryer if the system is still sealed. Your mechanic should be the one you ask about that. Hopefully he has a recovery system.
chieftaco
10
Oct 11, 2009 03:38 PM
freestyler_
11
Jun 14, 2009 04:23 PM
SuM Honda
Oct 6, 2008 08:40 PM
floriudabrain
Jan 31, 2006 07:04 AM
kmar111
Jun 20, 2004 05:25 PM
