Injen Headers
Old Aug 3, 2007 | 08:36 PM
Mike1995HondaPrelude's Avatar
Default Injen Headers
The mechanic changed my oil pan and gasket today. After taking off a portion of my headers, he discovered that my flange gasket (I believe thats what it is called) is broken. It is located at the part of the header that goes from 4 to 2.
It looks just like this http://www.phonecallsfromthede...0.jpg
I went to 10 different car shops performance and nonperformance, and I couldn't find a single fit. What is this piece called and how can I get it?
THANKS!!!
Old Aug 3, 2007 | 10:03 PM
preludestud11's Avatar
Default Re: Injen Headers (Mike1995HondaPrelude)
its just teh flange gasket, you probably will not be able to find one locally, best option is to get a sheet of gasket material from the parts store, and cut your own.
Old Aug 3, 2007 | 10:18 PM
M2B4's Avatar
Default Re: Injen Headers (preludestud11)
yeah u wont find one those ive tried and only found ordering online. local parts stores didnt have metal sheets to make my own just the paper ones
Old Aug 4, 2007 | 03:08 PM
Default Re: Injen Headers (M2B4)
how can i make my own? U know teh site i can get it from? Thanks
Old Aug 4, 2007 | 03:34 PM
no1knows908's Avatar
AutoZone stocks a big sheet its like $15 dollars. Just trace your old gasket with a sharpie or something and cut it with scissors or a razor blade.
Old Aug 4, 2007 | 05:02 PM
bluedlude's Avatar
cork gasket FTL . why would you even recommend that?
Old Aug 4, 2007 | 05:30 PM
Fresco's Avatar
Default Re: Injen Headers (bluedlude)
Search online for exhaust gasket material it's only a couple of dollars per sheet. They sell them in different dimensions, and you can also get hi-temp exhaust gasket material that is stronger than the original. I bought a Mr. Gasket brand sheet and replaced all of my original exhaust gaskets after pulling the exhaust.
Old Aug 4, 2007 | 09:52 PM
Default Re: Injen Headers (Fresco)
were they metal gaskets? I hear those are much better. Are they? How did you make them? THANKS
Old Aug 5, 2007 | 07:54 AM
i got my sheet at autozone for like $15 dollars, it looks like paper on teh outside, but it has metal screen in the middle, its high temp and works great, i have been using the same sheet for about a year now, never had to buy another gasket since i got this stuff. to cut it i just trace out what i need on the sheet, then youse a flat tip screwdriveer and it it with a hammer to cut through the metal.
SuciaEk420
Jan 1, 2012 03:29 PM
3s1k
Jun 1, 2011 04:36 PM
SoHc Ej1
Aug 14, 2007 12:03 PM
Extreez
Apr 18, 2007 04:34 PM
EFn00b619
Aug 6, 2004 07:29 PM
