100 octane
Old Jul 27, 2007 | 07:51 PM
rico892002's Avatar
Default 100 octane
whats up guys, running a JDM H22a wit a JDM ecu. was wonderin if using 100 octane would help n the performance n would it do any damage. i heard that runnin that high of an octane would eat up the cat but also heard that thats what they be using over n Japan so it would help performance wise. let me kno....
Old Jul 27, 2007 | 08:04 PM
snowblind7x's Avatar
Default Re: 100 octane (rico892002)
thats to high a octane for a stock compression motor. You would only need that high a octane if you had like 13:1 compression or so.
Old Jul 27, 2007 | 09:34 PM
98vtec's Avatar
moderator emeritus
Default Re: 100 octane (snowblind7x)
waste of money
Old Jul 27, 2007 | 11:21 PM
M2B4's Avatar
Default Re: 100 octane (98vtec)
honda calls for 91 octane stick with that i run 93 b/c i dont have many 91's here 87/89/93 kinda odd but o well
Old Jul 28, 2007 | 04:25 AM
flavah0wnz's Avatar
Default Re: 100 octane (M2B4)
ur gonna burn ur o2
Old Jul 28, 2007 | 04:36 AM
subydoored's Avatar
Default Re: 100 octane (flavah0wnz)
in japan the gas is anywhere from 91 to 100 octane
Old Jul 28, 2007 | 05:43 AM
Cyberdx16's Avatar
Default Re: 100 octane (subydoored)
higher octane will only allow your fuel to burn at higher temps. FI and high comp guys use higher rating octane to help prevent detonation (explosion of fuel due to it being compressed). on a stock motor its not gonna help out at all
Old Jul 28, 2007 | 08:47 AM
NTX
Guest
Posts: n/a
Default Re: 100 octane (Cyberdx16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyberdx16 &raquo;</TD></TR><TR><TD CLASS="quote">higher octane will only allow your fuel to burn at higher temps. FI and high comp guys use higher rating octane to help prevent detonation (explosion of fuel due to it being compressed). on a stock motor its not gonna help out at all</TD></TR></TABLE>
yup, im on e85
Old Jul 28, 2007 | 10:38 AM
E-Money's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rico892002 &raquo;</TD></TR><TR><TD CLASS="quote">whats up guys, running a JDM H22a wit a JDM ecu. was wonderin if using 100 octane would help n the performance n would it do any damage. i heard that runnin that high of an octane would eat up the cat but also heard that thats what they be using over n Japan so it would help performance wise. let me kno....</TD></TR></TABLE>
In Japan they have a different rating of octane/gasoline, same with Europe. I'm talking bout ROM, etc..
Old Jul 29, 2007 | 01:10 PM
91SI92's Avatar
what up cuzo. i ran 100 octane n the car n i did notice a difference in performance. it ran smoother n pulled a lil harder. it even started right up when i had it in the tank. i usually run the shell vpower(93) but i went 2 tha track so i put n bout half a tank of the 100.
Old Jul 29, 2007 | 11:49 PM
95greenlude's Avatar
Default Re: 100 octane (91SI92)
i only use 100 octane when i know i'll be spraying
Old Jul 30, 2007 | 05:24 AM
gavzter's Avatar
Default Re: 100 octane (95greenlude)
as said, the Japs use 100 RON fuel
Over here, our standard unleaded is 95 RON and jap engines run pretty crap on that to be honest. definitely notice performance difference when I use 99 or 100 RON premium fuel.
Also fuel economy is muchhh better on 100 RON. £ to mile 95 and 100 RON work out about the same, only with better/smoother performance with 100 RON.
I sure wouldnt like to run my engine on your american 91 RON.
Gavz
racetowin
Jul 15, 2006 09:29 AM
VtecDA9
14
Dec 11, 2003 08:51 AM
FifthGen
Oct 28, 2003 05:20 PM
CrOmEdOmEcHaMbEr
10
May 9, 2002 11:41 AM
ingrate
Jul 16, 2001 06:44 PM
