fuel pump problem
Old Jul 31, 2007 | 09:59 AM
fastbb2's Avatar
Default fuel pump problem
Why is it that when ever my car is really hot on the inside the damn fuel pump will not come on. Has anyone had this problem, and if so how do i fix it. The car a 92 prelude, stock f.p.
Old Jul 31, 2007 | 10:11 AM
carnot's Avatar
Default Re: fuel pump problem (fastbb2)
how many miles on the car? has the pump ever been replaced? it could be starting to fail. It also kinda sounds like an electrical and heat problem. Have you removed the cover in the trunk to see if there is a loose connection?
Old Jul 31, 2007 | 10:13 AM
street_ride14's Avatar
Main relay !!
Old Jul 31, 2007 | 10:15 AM
fastbb2's Avatar
Default Re: fuel pump problem (carnot)
yes i have removed the cover, the connection is goodthe car has like 2xx,xxx miles on it but i had replaced it with a walbro 255 and it shut off when ever it felt like so i put the stock one back in and it was fine for about a yr and now its doing it again
Old Jul 31, 2007 | 10:18 AM
fastbb2's Avatar
Default Re: (street_ride14)
the car will start after an hr of cooling down so if it was the main relay wouldn't it just not start
Old Jul 31, 2007 | 10:30 AM
Default Re: (fastbb2)
Nope, this just happened to me yesturday. Fule Pump won't prime up because the Main relay is not turning it on. Your relay is not shot, but on its way. H-T's Search function is down right now, but if you Search on the Main Relay, you'll get many results.
Old Jul 31, 2007 | 11:03 AM
fastbb2's Avatar
quick question then.... where is it, i called the local honda dealer and they said it was somewhere under the dash, is it in the fuse box under the dash?
Old Jul 31, 2007 | 11:08 AM
esedulerp5tenin's Avatar
under the dash, above the steering column
i hear its a PITA to remove completely, so ppl just unplug the bad one, plug the new one in, and zip-tie it up in there
Old Jul 31, 2007 | 11:33 AM
fastbb2's Avatar
Default Re: (esedulerp5tenin)
well i found it and i see why people zip tie the new one in
Old Jul 31, 2007 | 03:28 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastbb2 &raquo;</TD></TR><TR><TD CLASS="quote">well i found it and i see why people zip tie the new one in</TD></TR></TABLE> I will admit i did that to the one on my beater 92.
wwolf771177
Mar 25, 2013 02:54 PM
Origin
Dec 19, 2008 10:45 AM
8_6 luder
Aug 5, 2007 06:27 AM
nonbox
Jan 30, 2006 01:00 PM
mercury
Jul 16, 2002 07:15 PM
