How to read code for CEL?
Old Jul 31, 2007 | 07:01 AM
ralpheezy's Avatar
Default How to read code for CEL?
I have a CEL on right now. I took it to two different places to see if they could read what the code is but they both said they can't do it with OBD1 cars.
Is this true? If not, how would I get the code?
btw search keeps coming up as error.
Old Jul 31, 2007 | 07:05 AM
mgags7's Avatar
there is a 2-pin connector behind the radio on the driver side. jump those two wires.
Old Jul 31, 2007 | 08:40 AM
giddyup21's Avatar
Default Re: (mgags7)
Jump the 2 pin connector (you can use a paperclip or wire), with the key out. Then put the key in, turn it to on but don't start it. Watch your CEL flash on the screen. A long flash = 10, a short flash = 1. Add it all up and that's your code.
Old Jul 31, 2007 | 10:37 AM
graham b's Avatar
Default Re: (giddyup21)
obd1 has the 3 pins and u connect the 2 on the outside.right?
i have obd2 and its the 2 pin, just pulled it today
http://www.preludezone.com/showthread.php?t=2363
Old Aug 1, 2007 | 07:14 PM
ralpheezy's Avatar
when it flashes will it flash the code just once or will it repeat?
thanks for the responses guys. and thanks for the link too.
Old Aug 1, 2007 | 07:26 PM
m00nr0ck Si's Avatar
Default Re: (ralpheezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralpheezy &raquo;</TD></TR><TR><TD CLASS="quote">when it flashes will it flash the code just once or will it repeat?
thanks for the responses guys. and thanks for the link too.</TD></TR></TABLE>
it will flash the first digit slow and the second digit fast and then continue to repeat
M2B4's Avatar
odb1 is 2 pin trust me done it plenty of times. and it will flash the codes 3 times.
Old Aug 16, 2007 | 09:45 AM
ralpheezy's Avatar
Default Re: (M2B4)
i went down there today and i had a yellow connector that wasn't plugged into anything. it was a 2 pin so i tried it but i couldn't get any codes from it.
is it because my CEL would go away and only come every once in a while or could i have just used the wrong connector? is the connector supposed to blue just like the ones in the picture?
Old Aug 16, 2007 | 09:50 AM
giddyup21's Avatar
CEL should be stored until you reset your ECU by disconnecting your battery.... meaning you did it wrong.
GriFFIthS
Honda Civic (2001 - 2005)
Feb 21, 2011 04:26 AM
karrar55
Aug 29, 2009 04:52 AM
team 15
Jul 1, 2007 06:57 PM
UtahRockabilly
Mar 28, 2004 10:43 AM
Pfieff
Jul 28, 2003 04:19 PM
