ecu problems for h22
Old Jul 30, 2007 | 07:15 AM
birwin12's Avatar
Default ecu problems for h22
i have a 95 prelude with a 98 h22. the car recently start acting up i switch out the
the ecu and it fixed it for now. what can happen if you do not have the right ecu?
can it cause more problems?
ecu p14 to p28
Modified by birwin12 at 1:35 PM 7/30/2007
Old Jul 30, 2007 | 07:26 AM
92hondalude's Avatar
Default Re: ecu problems for h22 (birwin12)
what do you mean right ecu?
what ecu are you running?
Old Jul 30, 2007 | 09:08 AM
PrecisionH23a's Avatar
Yes, running the wrong ecu can cause problems. The p72 and p28 will lead to lean conditions.
Run your p13 ecu unless you are running some sort of EMS with the P72/p28 ecu.
Old Jul 30, 2007 | 12:33 PM
birwin12's Avatar
Default Re: ecu problems for h22 (PrecisionH23a)
it had a p 14 in it that started acting up. i had a spare p28 and thats what is in it right now.
what do you me lean condition?
Old Jul 30, 2007 | 12:42 PM
Maharajamd's Avatar
It will run the engine lean, not give it enough gas). There are a few other things it won't do correctly but I can't remember what they are... lol.
Old Jul 30, 2007 | 02:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birwin12 &raquo;</TD></TR><TR><TD CLASS="quote">it had a p 14 in it that started acting up. i had a spare p28 and thats what is in it right now.
what do you me lean condition?</TD></TR></TABLE>
A p14 is for 240cc injectors and your 98 h22 has 290cc injectors unless you swapped them out for the obd1 injectors. Also, the obd1 vtec h22 has 345cc injectors. The p13 ecu is for obd1 345cc injectors and the p28 is for 240cc injectors. The p14 ecu also does not have vtec since it is for the h23a1 motor.
Old Aug 3, 2007 | 01:52 PM
KOOCH 750's Avatar
I GOT PROBLEMS WITH AN ECU CAN U HELP ME OUT????
Old Aug 3, 2007 | 02:39 PM
Eddiebx's Avatar
Default Re: ecu problems for h22 (KOOCH 750)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOOCH 750 &raquo;</TD></TR><TR><TD CLASS="quote">I GOT PROBLEMS WITH AN ECU CAN U HELP ME OUT????</TD></TR></TABLE>
yes, get a new ecu
Old Aug 3, 2007 | 02:56 PM
nabin's Avatar
Default Re: ecu problems for h22 (Eddiebx)
hahaha no ****. --------^
Old Aug 3, 2007 | 03:56 PM
hybrid2007's Avatar
Default Re: ecu problems for h22 (nabinger)
Run the correct ecu for your engine unless you are getting it chipped and tuned.
Old Aug 3, 2007 | 05:19 PM
nabin's Avatar
Default Re: ecu problems for h22 (hybrid2007)
just a heads up.....my buddy blew his gsr running a p28 - WRONG ECU WILL F YOUR **** UP!!
Old Aug 3, 2007 | 10:15 PM
JBirch_97Prelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Yes, running the wrong ecu can cause problems. The p72 and p28 will lead to lean conditions.
Run your p13 ecu unless you are running some sort of EMS with the P72/p28 ecu.</TD></TR></TABLE>
Old Aug 3, 2007 | 10:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birwin12 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 prelude with a 98 h22. the car recently start acting up i switch out the
ecu p14 to p28
Modified by birwin12 at 1:35 PM 7/30/2007</TD></TR></TABLE>
When you say 98 H22, do you mean the H22A4? Also when you use a P28 it takes away the use of you Secondary Intake Runners.
I would like to know how your engine harness is set up? What are are you using from your H22A4?
ThumperDumper
Aug 29, 2013 08:33 AM
h22eg607
Oct 3, 2007 08:42 AM
slowsleeper
Aug 25, 2005 11:49 AM
spoonhatchblack
Nov 4, 2004 10:12 AM
cal_
Sep 14, 2004 04:24 PM
