Need Electrical Help
Old Aug 5, 2007 | 05:54 AM
typeS's Avatar
Default Need Electrical Help
I hooked up a cable for my ipod to my alpine deck last week. Haven't really driven much since then. Went out last night and a low beam headlight went out, its a one year old silverstar. Stopped somewhere on the way home and when I left the other low beam died withing 15 seconds after starting the car, also one year old silverstar. Got home on my brights. Check this morning and one of the brights is now out, those are regular sylvania.
I checked the battery, it is good and new. Checked grounding points, those are good. I'm getting 14.44 volts at the headlights. What else should I do? I'm not really good with the diagrams in the manual. Thank you.
Old Aug 5, 2007 | 06:33 AM
dagle's Avatar
Default Re: Need Electrical Help (typeS)
arent ur bulbs 12V?
Old Aug 5, 2007 | 06:55 AM
typeS's Avatar
Default Re: Need Electrical Help (dagle)
yeah, good point. can someone check what their output is at the headlight? i just put a voltmeter on the lightbulb, you don't even have to disconnect it.
Old Aug 5, 2007 | 07:17 AM
dagle's Avatar
check ur wires, ground, obvious stuff, then start doing trial and error and putting in known good bulbs and whatnot. electricals are a headache. im having some trouble right now too x.x
Old Aug 5, 2007 | 06:15 PM
typeS's Avatar
So I pulled out the Ipod cable, unplugged radar detector. Put in new low beams. Now with low beams turned on, I have passenger low beam barely on, passenger high beam barely on, driver high beam barely on, and driver low beam fully on. With high beams selected on, I have only driver low and high beams illuminated. Any suggestions gentlemen? Otherwise I'm going to the dealer tomorrow as I must travel for work this week.
Old Aug 6, 2007 | 06:35 AM
typeS's Avatar
I know there are some electrical guys on the board. I need some help, this has me confused.
Old Aug 7, 2007 | 07:46 PM
typeS's Avatar
I was had by a thorny stick that found its way to a headlight wire, thus shorting and causing an arc according to the mechanic at honda.
924doorEG
Aug 15, 2011 11:20 PM
norcalB18
Oct 29, 2010 08:28 PM
01oemTeggy
Sep 1, 2010 02:51 PM
sik_sol
Apr 14, 2005 01:51 PM
RedRex8
May 23, 2003 06:09 AM
