H22a Problem HELP!!!
Old Aug 4, 2007 | 04:26 PM
h22a1_julien's Avatar
Default H22a Problem HELP!!!
Ok so im driving on the highway at about 110-115...all off a sudden the car starts dying on me like there was no power?..check engin came on as soon as it was dying.....downshifted to 4th gear absolutely NO power what so ever and then the car dies......Looked under the hood..and nodessed the distributer was separated about a half inch or less from the head?!?!...couldn't start the car at all..and i know if i tighten up the 3 bolts that were loosend up could effect my timing?!...and cause BIG problems..
Could some one help me if this has a big effect on the motor?..or if you have any suggestions..!
Thx
Old Aug 4, 2007 | 05:48 PM
JasonST's Avatar
Default Re: H22a Problem HELP!!! (h22a1_julien)
Just put the dizzy back on correctly and tighten it up, it only goes on one way, it may be a tad big out of timing but just aim somewhere for the middle and use a timing gun to set timing l8r.
Old Aug 4, 2007 | 05:59 PM
bluedlude's Avatar
Default Re: H22a Problem HELP!!! (JasonST)
damn dude, the torque wrench ownz you.
Old Aug 4, 2007 | 06:03 PM
98vtec's Avatar
moderator emeritus
of course it is going to effect the engine, the exhaust cam lost contact with the distributor........
Old Aug 4, 2007 | 06:14 PM
gogunkergorilla's Avatar
somebody forgot to torque some bolts
put it back together...maybe your lucky and didn't break anything
Old Aug 4, 2007 | 06:43 PM
Eddiebx's Avatar
check the distributor shaft, and the key way in the cam to see if it got chewed up when it popped off. hopefully thats all fine. if so, throw it back in, check the timing and hope she works,
Old Aug 4, 2007 | 07:53 PM
Default Re: (Eddiebx)
Thx for the replys boys.....its fixed now distributer was basicly separated and wasnt making any contact with the cam...and yeah it could have been much worse....dindt effect the timing cuz i dint try to start it much...but shes runnin good now
pcguy760
May 31, 2007 12:19 AM
monalisa overdrive
Jan 22, 2006 07:14 PM
preluder
May 19, 2003 07:00 AM
