92 lude Si problem
Old Apr 12, 2008 | 08:48 PM
Josh Vertiz's Avatar
Default 92 lude Si problem
ok so i get off work and stop at the local gas station to pick up something to drink and i finished payin and get back into my car and start her up she starts but suddenly the rpms suddenly drop and she dies,so i try to start her up again but it wont even fire up,so i wait bout 2-3 minutes and she started without no problems and it did the same thing today also my headlights turn on but my gauge cluster lights wont even turn on ..thanks
__________________
Old Apr 13, 2008 | 12:07 AM
outlawstar27's Avatar
Default Re: 92 lude Si problem (Josh Vertiz)
check your main relay.
Old Apr 13, 2008 | 01:51 PM
vlang29's Avatar
Default Re: 92 lude Si problem (outlawstar27)
Most likely Ignition switch
Old Apr 13, 2008 | 02:19 PM
civic_racer_97's Avatar
Default Re: 92 lude Si problem (vlang29)
Check all your fuses and check you main relay as said above.
Old Apr 14, 2008 | 07:24 AM
92nb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">Most likely Ignition switch</TD></TR></TABLE> x2
I second what vlang29 said. It's definitely your ignition switch. Mine just went out, except both my speedo/tach and instrument panel went on and off at the same time. $280 job at the dealer if you don't have time to do it yourself.
I would highly say that's the issue at hand. I could be wrong, but that's my 2 cents.
Old Apr 15, 2008 | 11:13 PM
Default Re: 92 lude Si problem (92nb)
ok so i checked my fuses and my small light fuse was burnt and so was my clock and radio fuse and replaced them asap and my dash lights turned on ...but the car still dies...im gonna check that relay fuse...thanks guys
Old Apr 17, 2008 | 08:40 AM
found the main relay but havin a hard time taking it out... any suggestions
Old Apr 17, 2008 | 08:46 AM
gotjnco's Avatar
yea thats normal... keep on trying...
Old Apr 17, 2008 | 09:41 AM
marks_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Josh Vertiz &raquo;</TD></TR><TR><TD CLASS="quote">found the main relay but havin a hard time taking it out... any suggestions </TD></TR></TABLE>
I think you can just unclip the housing of it and it comes out. you dont have to get the bolt out if i remember correctly.
Old Apr 17, 2008 | 03:29 PM
socialistic's Avatar
The relay itself has a plastic housing/cover...it's that cover that holds the whole thing to the car. You want to remove the relay from the cover...leaving the cover attached to the car. Use two flathead screw drivers or two butter knives...one on each side of the relay to pull back the tabs on the casing that hold the relay in.
It's a lot easier than trying to remove the whole thing, and snaps right back in to place when you're done.
Be sure to check the solder-board on the relay once it's out. Those solder joints split around the wire/post that goes through the board. Use a soldering iron to re-heat the solder so it's a solid connection again. Mine had 6 bad solder joints...caused all sorts of electrical havoc until I fixed it. Be sure to not let the solder move around...you don't want to cross connections that weren't meant to be crossed. Clean up any rosin/flux when you're done.
skazoo
Jul 11, 2009 12:09 PM
Skipper75
22
Mar 8, 2007 07:02 PM
hondaZvic
Jul 10, 2004 05:10 AM
foxedogg
Jul 16, 2003 08:00 AM
