ECU
Old Apr 21, 2008 | 04:40 PM
amalby's Avatar
Default ECU
I looked in my car and I got the ECU code which is 37820-P12-A00.
So I have a P12 ECU. I want to run Hondata because I am running boost in less than a month. But my problem is that the ECU that I have does not appear to support Hondata. So I was wondering what ECU I can use. I have a fully built F22a Motor. it is running great but I am not getting the capabilities I should. Like my rev limiter is only at 6500 when the new one is around 8,000rmp.
Please Help. . . just wondering what ECU I can run.
Old Apr 21, 2008 | 05:35 PM
98vtec's Avatar
moderator emeritus
Default Re: ECU (amalby)
you can run any OBD1 nonvtec ecu you want that is supported by hondata.
Old Apr 22, 2008 | 08:35 PM
amalby's Avatar
Default Re: ECU (98vtec)
Thanks alot man. And it will just plug in correct.
These are the ECU supported by hondata that are OBD 1 non vtech.
-PR4
-P06
-P74
-P75
Is one of these superior to the other? or are they pretty much the same?
EL TYPE R
Oct 26, 2012 10:46 PM
vy3tnamezz
Engine Management and Tuning
Sep 20, 2009 10:43 AM
chicken18
Mar 25, 2009 06:26 PM
BUCK_NASTY
Apr 20, 2007 08:55 PM
trick_db
Apr 30, 2006 09:10 AM
