suggestions
Old Apr 11, 2008 | 11:41 AM
IAluder95's Avatar
Default suggestions
so i was disassembling an h23a1. it has over 200K on it. i needed some bolts and hoses ect off it before i give to rosko for his ultimate project.
either way, a lot of the hoses feel almost glued to the piping and block. any idea of how to get these off with out cutting them ect? i tried to muscling them off. but i weight 140 lbs.
Old Apr 11, 2008 | 12:18 PM
Acidcrakker's Avatar
Default Re: suggestions (IAluder95)
Haha, Im 240 and my motor had 112k on it and it was still a bitch getting all the hoses off. What worked best was vice grips. Id clamp them on the end of the hoses and give them a little twist, until the were removable.
Old Apr 11, 2008 | 12:19 PM
AssItch1's Avatar
i usually get some pliers around them and turn... they should come off...
Old Apr 11, 2008 | 06:14 PM
gstrudler's Avatar
Default Re: suggestions (AssItch1)
I prefer a flat head screwdriver and pry at the ends to loosen them up; it will help break the seal that formed.
Old Apr 11, 2008 | 06:21 PM
Sampsonite987's Avatar
Default Re: suggestions (gstrudler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gstrudler &raquo;</TD></TR><TR><TD CLASS="quote">I prefer a flat head screwdriver and pry at the ends to loosen them up; it will help break the seal that formed.</TD></TR></TABLE>
I run the flat head all the way around (or at least as much as you can) to seperate the hose, the get some pliers/vise grips and twist.
Old Apr 11, 2008 | 06:26 PM
IAluder95's Avatar
no wd40?
Old Apr 11, 2008 | 09:01 PM
Hawkze_2.3's Avatar
Default Re: (IAluder95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">no wd40?</TD></TR></TABLE>
That should help too, but the best thing, like people have said, it to grip the hose good and twist it to break the seal.
Old Apr 11, 2008 | 09:52 PM
IAluder95's Avatar
ill try harder tomorrow
Old Apr 12, 2008 | 05:52 PM
h22 civic's Avatar
a pair of 440 channelocks around hose and twist
Old Apr 12, 2008 | 05:56 PM
Jsarv's Avatar
Default Re: (h22 civic)
Get a hose hook from Snap on. Looks like a curled pick, works freaking awesome on Heater core hoses that are a bitch.
Think it was like $15, works every time!
Or some Channel locks will do it.
Old Apr 12, 2008 | 09:19 PM
pkolaboy's Avatar
i was prepping my engine to take it out today and i came to that same prob. i just stuck a flathead on the end and beat the end with a hammer...came right off...
Old Apr 12, 2008 | 09:37 PM
IAluder95's Avatar
channellocks? ill look at that.
Old Apr 12, 2008 | 09:48 PM
marks_lude's Avatar
use a flathead and pry the end of it. they are fused on, and also act like a chinese finger trap if you just pull on the hose.
wowy978
Jul 25, 2008 03:25 PM
B18C_EJ8
Oct 29, 2007 04:33 PM
130R
Welding / Fabrication
Jul 23, 2007 06:29 AM
shutta
May 14, 2006 08:27 PM
LSEGHATCH
Aug 14, 2005 09:02 AM
