vss issues
Old Apr 16, 2008 | 07:53 AM
94SuperLudeSI's Avatar
Default vss issues
i have a 92 lude w/jdm h22 swap
the plug on my vss is good, but the one coming from the harness that plugs into it is broken off.... i want to just cut off the other plug and direct wire it....but the wires going in and coming out al seem to be different colors, anyone have an idea of which ones hook to each other???
lookatdalude is online now Report Post Edit/Delete Message
Old Apr 16, 2008 | 09:24 AM
CHK4TIX's Avatar
Default Re: vss issues (94SuperLudeSI)
im not sure of the wire colors, but I wouldn't just direct wire it because you would have to undo the two hoses for the vss every time you wanted to take out the tranny or remove the engine. I would search and find a hacked up harness and buy a replacement end
Old Apr 16, 2008 | 10:55 AM
mgags7's Avatar
get another connector for it, don't directly wire it in
get a helms manual to figure out the wire colors, or they may just be apparent if you go to a junkyard to get another connector.
G2_Fella
Oct 11, 2008 08:21 PM
marks97el
Sep 16, 2008 02:28 PM
PhrequenC
Aug 5, 2008 11:15 AM
9281hatch
Sep 11, 2006 12:18 PM
