Weird and Random cut outs while driving.
Old Apr 12, 2008 | 01:57 PM
Roca fella Bryan's Avatar
Default Weird and Random cut outs while driving.
Okay, my motor is a slightly modded JDM H22.
After all of the other problems I've had with it, they're finally fixed except for one. Sometimes I notice some type of brutal cut out when I shift hard.
Like say for instance, going from 1st to 2nd or 2nd to third at 7,500rpm. . . You can hit the gear perfect but suddenly the engine just falls on its *** like it encountered a fuel cut or something. Been trying to figure this out for a while, but it only happens at random. So what are your ideas?
Old Apr 15, 2008 | 05:00 PM
Default Re: Weird and Random cut outs while driving. (Roca fella Bryan)
bump.... any suggestions?
I still have the stock fuel pump in. Could that be a potential problem?
Old Apr 15, 2008 | 05:30 PM
snobordboy's Avatar
Moderator
If you are reving it that high, you may be hitting fuel cut right as you shift, so try shifting 100 rpm sooner, or get tuned, then you can know where your powerband is and where you really should shift.
Old Apr 15, 2008 | 07:16 PM
95greenlude's Avatar
Default Re: (snobordboi)
do your gauges go out too?
Old Apr 16, 2008 | 02:58 AM
It is dyno tuned. Chrome on a P28.... The rev limiter is set at 7900rpm, I normally shift at 7,500.
And it rarely cuts out that high... Its like right after you hit the next gear and you get ready to stomp the pedal again. As soon as you do, the engine falls on its *** sometimes.
And no, my gauges stay on. I know the tach will shut off if the ignition cuts out, so I figure its a fuel related issue...
luck_le
Acura TL, RL & ZDX
12
Aug 21, 2009 03:23 AM
WPG_5thgenprelude
Nov 9, 2004 01:19 AM
drewwatts23
Jun 14, 2004 11:41 AM
proton
Jul 9, 2002 02:59 PM
96b18c
Sep 17, 2001 04:13 AM
