Check engine light!!!! Please help
Old Apr 10, 2008 | 01:46 AM
h3rsh3y2001's Avatar
Default Check engine light!!!! Please help
ive got an 01 prelude with dc headers and exhaust and under drive pullys. My check engine light wont stop coming on and I was told I have a cylinder mis fire, would any of these be my problem and if so what could I do to fix it?
Old Apr 10, 2008 | 02:28 AM
98vtec's Avatar
moderator emeritus
Default Re: Check engine light!!!! Please help (h3rsh3y2001)
who told you this?
Old Apr 11, 2008 | 12:49 AM
Default Re: Check engine light!!!! Please help (98vtec)
I had it run on a code reader and it read that all 4 cyliders were mis fireing.
Old Apr 11, 2008 | 05:54 AM
Acidcrakker's Avatar
coil pack
Old Apr 11, 2008 | 07:40 AM
98vtec's Avatar
moderator emeritus
when was the last time you replaced:
ignitor
distributor rotor and cap
spark plugs
spark plug wires
fuel filter
Have you ever cleaned the EGR ports?
replaced your o2 sensor?
If the coil was bad the engine would not get spark so thats obviously not the problem.
Old Apr 11, 2008 | 07:49 AM
Hawkze_2.3's Avatar
Default Re: Check engine light!!!! Please help (Acidcrakker)
Yeah, it probably needs a tune up. Plugs, wires, cap, rotor, etc like Blake said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">coil pack</TD></TR></TABLE>
Probably not
Old Apr 11, 2008 | 08:10 AM
Default Re: Check engine light!!!! Please help (Hawkze_2.3)
The coil pack can be faulty and still work.
Its usally over looked. Cap, rotor and wires are usally replaced first, but when that is said and done, there is still random misfires, the coil is usally at fault.
Old Apr 11, 2008 | 09:44 AM
Hawkze_2.3's Avatar
Good point, something to check.
Old Apr 12, 2008 | 12:58 AM
I replaced the plugs and wires a few weeks ago cause I thought that was the problem, the coil pack is brand new, I dont know about the fuel fitler. Is it true you have to run premium in these things or would plus be ok?
Old Apr 12, 2008 | 04:31 AM
91 octane
Old Apr 12, 2008 | 05:07 AM
vlang29's Avatar
H motors are designed to run on 91+, that is why it says PREMIUM UNLEADED ONLY on both the gauges, and your fuel door.
However they will run fine on less octane, but you won't get equal engine performance or fuel mileage.
It is worth the $2/tank to get the good stuff.
Psychoguitarz
Oct 27, 2012 04:23 AM
docppo
Honda CR-V & Element
Jun 21, 2011 04:54 AM
wiseguyoncouch
Jan 30, 2008 09:47 AM
Biscuit
Oct 17, 2004 06:29 AM
XtremeCarTuner
Jul 10, 2003 07:48 PM
