code 12? HELP PLEASE!!!!!!
Old Jun 9, 2008 | 06:52 PM
luckytempo93's Avatar
Default code 12? HELP PLEASE!!!!!!
hey im new here and a new owner of an 87 prelude 2.0si. i like it so much more over my 96jetta. well i bought it and the pgm-fi light would come on after driving. the idle would stay on 1100 when the light is on. i have found the light to blink 12 times which i was told it is an EGR fault. what are some common problems? and would anyone know how to get to the fuel pump? i have to hit the tank sometimes to get it to start. my hand has some nice cuts on it. but i love the car. PLEASE HELP
Old Jun 9, 2008 | 07:25 PM
sup3rd's Avatar
Default Re: code 12? HELP PLEASE!!!!!! (luckytempo93)
1 P0131 Primary HO2S Circuit Low Voltage (Sensor 1)
1 P0132 Primary HO2S Circuit High Voltage (Sensor 1)
3 P0107 MAP Circuit Low Input
3 P0108 MAP Circuit High Input
4 P0335 CKP Sensor Circuit Low Input
4 P0336 CKP Sensor Range/Performance
5 P0106 MAP Circuit Range Or Performance
5 P1128 MAP Lower Than Expected
5 P1129 MAP Higher Than Expected
6 P0117 ECT Circuit Low Input
6 P0118 ECT Circuit High Input
7 P0122 TP Sensor Circuit Low Input
7 P0123 TP Sensor Circuit High Input
7 P1121 Throttle Position Lower Than Expected
7 P1122 Throttle Position Higher Than Expected
8 P1359 CKP/TDC Sensor Connector Disconnection
8 P1361 TDC Sensor Intermittent Interruption
8 P1362 TDC Sensor No Signal
9 P1381 Cylinder Position Sensor Intermittent Interruption
9 P1382 Cylinder Position Sensor No Signal
10 P0111 IAT Sensor Circuit Range/Performance
10 P0112 IAT Sensor Circuit Low Input
10 P0113 IAT Sensor Circuit High Input
12 P1491 EGR Valve Lift Insufficient Detected
12 P1498 EGR Valve Lift Sensor High Voltage
13 P1106 BARO Circuit Range/Performance
13 P1107 BARO Circuit Low Input
13 P1108 BARO Circuit High Input
14 P0505 ICS Malfunction
14 P1508 IAC Valve Circuit Failure
14 P1509 IAC Valve Circuit Failure
14 P1519 Idle Air Control Valve Circuit Failure
17 P0500 VSS Circuit Malfunction (M/T)
17 P0501 VSS Circuit Range/Performance (A/T)
20 P1297 Electrical Load Detector Circuit Low Input
20 P1298 Electrical Load Detector Circuit High Input
21 P1253 VTEC System Malfunction
22 P1257, P1258, P1259 VTEC System Malfunction
23 P0325 KS Circuit Malfunction
30 P1655 SEAF/SEFA/TMA/TMB Signal Line Failure
30 P1681 A/T FI Signal A Low Input
30 P1682 A/T FI Signal A High Input
31 P1686 A/T FI Signal B Low Input
31 P1687 A/T FI Signal B High Input
34 P0560 Powertrain Control Module (PCM) Backup Voltage Circuit Low Voltage
41 P0135 Front HO2S Heater Circuit Fault (Sensor 1)
41 P1166 Primary HO2S (No. 1) Heater System Electrical
41 P1167 Primary HO2S (No. 1) Heater System
45 P0171 System Too Lean
45 P0172 System Too Rich
48 P1162 Primary HO2S (No. 1) Circuit Malfunction
48 P1168 Primary HO2S (No. 1) LABEL Low Input
48 P1169 Primary HO2S (No. 1) LABEL High Input
54 P1336 CSF Sensor Intermittent Interruption
54 P1337 CSF Sensor No Signal
58 P1366 TDC Sensor No. 2 Intermittent Interruption
58 P1367 TDC Sensor No 2 Signal
61 P0133 Primary HO2S Circuit Slow Response (Sensor 1)
61 P1149 Primary HO2S (Sensor 1) Circuit Range/Performance Problem
61 P1163 Primary HO2S (No. 1) Circuit Slow Response
61 P1164 Primary HO2S (No. 1) Circuit Range/Performance
61 P1165 Primary HO2S (No. 1) Circuit Range/Performance
63 P0137 Secondary HO2S Circuit Low Voltage (Sensor 2)
63 P0138 Secondary HO2S Circuit High Voltage (Sensor 2)
63 P0139 Secondary HO2S Circuit Slow Response (Sensor 2)
65 P0141 Secondary HO2S Heater Circuit Fault (Sensor 2)
67 P0420 Catalyst System Efficiency Below Threshold
70 P0700, P0715, P0720, P0725, P0730, P0740, P0753, P0758, P0763, P0780 A/T Concerns
70 P1660 A/T FI Signal A Circuit Failure
70 P1705, P1706, P1738, P1739, P1753, P1758, P1768, P1773, P1785, P1786, P1790, P1791, P1792, P1793, P1794 A/T Concerns
70 P1870, P1873, P1879, P1885, P1886, P1888, P1890, P1891 A/T Concerns
71 P0301 Misfire Cyl. 1 Or Random Misfire
72 P0302 Misfire Cyl. 2 Or Random Misfire
73 P0303 Misfire Cyl. 3 Or Random Misfire
74 P0304 Misfire Cyl. 4 Or Random Misfire
75 P0305 Misfire Cyl. 5 Or Random Misfire
76 P0306 Misfire Cyl. 6 Or Random Misfire
80 P0401 EGR Insufficient Flow Detected
86 P0116 ECT Circuit Range Or Performance
90 P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
90 P1457 EVAP Emission Control System Leak Detected (Control Canister System)
91 P0451 Fuel Tank Pressure Sensor Range/Performance
91 P0452 Fuel Tank Pressure Sensor Circuit Low Input
91 P0453 Fuel Tank Pressure Sensor Circuit High Input
92 P0441 EVAP Emission Control System Improper Purge Flow
92 P1459 EVAP Emission Purge Flow Switch Malfunction
— P0300 Random Misfire
— P1486 Thermostat Range/Performance Problem
— P1607 ECM/PCM Internal Circuit Failure A
— P1676 FPTDR Signal Line Failure
— P1678 FPTDR Signal Line Failure
71–74 P1300 Multiple Cylinder Misfire Detected
Old Jun 9, 2008 | 07:26 PM
sup3rd's Avatar
Default Re: code 12? HELP PLEASE!!!!!! (sup3rd)
hope that helps a little..
Old Jun 13, 2008 | 08:47 PM
well i found out that the egr valve lift sensor is reading 1.42v with no vaccume. the sensor should read around 1.2v. the ecm is "thinking its open" when it should not be. i cleaned it out and still the same reading. I need an egr. if anyone has one to fit a 1987 honda prelude with the 2.0si engine i would be glad to buy it used. i know there are some of you who block that off... it has a vaccume line going to it and a 3 wire sensor on top. PLEASE
Old Jun 13, 2008 | 10:36 PM
prelude_93vtec's Avatar
Did you check Honda? If not, check eBay. If anything, you can always block yours off too.
Old Jun 16, 2008 | 02:51 PM
Default Re: code 12? HELP PLEASE!!!!!! (prelude_93vtec)
i want to make the light stay off. i went to the junk yard and found the right egr valve and still the same proble. found out that the egr is not getting vaccume and i need to get some real help. so if you have this type of system and would love to help me out let me know. and i will send my email with my phone and try to figure this out. thanks.
PhillW
Feb 24, 2013 11:54 PM
zaks1
14
Dec 4, 2012 10:24 AM
turboed rhd
Mar 17, 2010 08:47 PM
justinb
Jun 2, 2005 03:39 PM
