check engine light not on?
Old Jun 19, 2008 | 05:29 PM
SLOSI7's Avatar
Default check engine light not on?
alot of you prolly thought wow this kid is a dumb *** and it means there is nothing wrong w/ you engine but my ? is on all other hondas i have tried when you turn the key to the on position(not trying to start but just on) the light comes on but on my non running 1992 prelude si w/ an h23a1 it doesnt, symptoms of the car when it died were it was driving fine then sputtered then died completly. i couldnt hear the fuel pump priming so i thought that was it so i replaced that, it didnt work so i figured main relay and replaced that also and that wasnt it either and i just found out im not getting any spark from the plug wires either but everything else works electrical wise but the motor wont turn over. any ideas?
Old Jun 19, 2008 | 06:31 PM
Acidcrakker's Avatar
Default Re: check engine light not on? (SLOSI7)
Have you tested your spark system? Coil, wires, plugs, dizzy. See if the coil will spark
flanker
Jul 19, 2015 05:08 AM
elite01
Honda Civic (2001 - 2005)
20
Nov 21, 2009 04:00 PM
Mik2006
Jul 31, 2009 02:54 PM
tyler100
Aug 24, 2008 06:28 AM
filip-s
Oct 26, 2006 07:22 AM
