lowest offset
Old Jun 13, 2008 | 01:10 PM
bubxba's Avatar
Default lowest offset
does anyone know the lowest offset you can use on e 4th gen.?,and idk how wide the rim would be, i jsut need some like guesstaments on the width of the tire with a low offsets.o i need to know as son as possible, and i dk cause not alot of people put low offsets on there 4th gens, please let me know
thanks.
Old Jun 13, 2008 | 01:19 PM
93WhiteLude's Avatar
Default Re: lowest offset (bubxba)
i dont know about the lowest but i have a +21 offset in the front and a +16 in the rear of my lude. and these are on 15x6 1/2 wheels
Old Jun 13, 2008 | 03:06 PM
Acidcrakker's Avatar
Default Re: lowest offset (93WhiteLude)
+40 on a stock set up would be the lowest.
Anything else will run into problems without sufficent reaserch.
Old Jun 13, 2008 | 05:56 PM
dartonh22's Avatar
Default Re: lowest offset (Acidcrakker)
i have 225/17/45 +48 offset on my 4th gen 5 lug conversion lowered 2 inches. no rubbing.
Old Jun 14, 2008 | 07:13 AM
bubxba's Avatar
what wheels are you running?im worried cause i was either bbs rs rims or some work equip 03's.think any of hose will work?
Old Jun 14, 2008 | 12:57 PM
dartonh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubxba &raquo;</TD></TR><TR><TD CLASS="quote">what wheels are you running?im worried cause i was either bbs rs rims or some work equip 03's.think any of hose will work?</TD></TR></TABLE>
there rotas i dont think the brand matters just know the offset. i cant answer that question.
Old Jun 14, 2008 | 02:24 PM
dye4p8ntbll21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i dont know about the lowest but i have a +21 offset in the front and a +16 in the rear of my lude. and these are on 15x6 1/2 wheels</TD></TR></TABLE>
Can you post up some pics, i would like to see how that looks.
Modified by dye4p8ntbll21 at 2:50 PM 6/15/2008
Old Jun 14, 2008 | 08:49 PM
bubxba's Avatar
Default Re: lowest offset (dye4p8ntbll21)
sry, i wasnt thinking ill get some numbers for you and please post some p[ics if you ahve any i would also really liek to see them.
Old Jun 14, 2008 | 08:54 PM
bubxba's Avatar
http://www.dragwheels.com/product.asp?ID=110 will these work you think?
Old Jun 15, 2008 | 12:08 PM
bb4socal's Avatar
You can go with a 0 offset...check out i believe page 30 of the 4th gen prelude picture thread. Theres a guy with red rims that are 15" with 0 offset. that **** looks bad ***!
FYI i know its 0 offset because i asked him.
Old Jun 15, 2008 | 02:11 PM
bubxba's Avatar
Default Re: lowest offset (bb4socal)
hell yeah thanks man, you dont know how wide the rims are do you?i jsut wanna make sure.
Old Jun 15, 2008 | 08:31 PM
bubxba's Avatar
bump. sry i need to know asap.
Old Jun 15, 2008 | 09:09 PM
bb4socal's Avatar
no but hey are 15" i believe.
Old Jun 15, 2008 | 09:41 PM
this was at a 2 finger gap i have it at one finger now but it only rubs when i hit a steep bump. ill get better picture tomorrow
Modified by 93WhiteLude at 10:46 PM 6/15/2008
Modified by 93WhiteLude at 10:48 PM 6/15/2008
Old Jun 18, 2008 | 02:05 PM
bubxba's Avatar
looks good,thanks for the pics.
but jsut to make sure ebfore i order these wheels, does anyone else know somethign i dont about usign a 0 offset, i jsut want these http://www.dragwheels.com/product.asp?ID=110 to work
Old Jun 19, 2008 | 12:25 AM
jmai86's Avatar
93whitelude is getting away with 0 offset because he's not lowered that much, and even then it still rubs a little.
If you're not lowering your car much at all, (i'm talking maybe an inch) then 0 offset will probably work, but will look like as$.
If you are going to lower your car a decent bit, you'll need fender rolling, pulling, and lots and lots of camber to make it work. When you finally get it to not rub, you've ruined your body panels a good bit, destroyed any kind of handling with all that camber you'll be running, and IMO, end up with a$$.
It's just not worth it IMO. I'm lowered 2.25" with +43 wheels and just barely got away with not rubbing.
EDIT - Also be aware that say, +40 on 7" wide wheels will not be the same as +40 on 8" wheels. Use this calculator to see what effect width and offset have on each other in terms of how far the wheel is pushed out. http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jun 19, 2008 | 04:47 PM
my9thtry's Avatar
Default Re: lowest offset (jmai86)
I find this offset calculator alot better http://www.wheelsmaster.com/rt_specs.jsp good luck.
Old Jun 19, 2008 | 06:50 PM
GtechPro's Avatar
When you talk about offset you have to have a specific wheel size in mind, diameter and width.
And as usual, tires are the last thing on most people's minds...
Are you planning on keeping the original tire overall diameter? Do you at least want it to be close or do you not care at all?
Do you care if you have to "roll" the fenders or not? Do you care about camber?
All these things matter.
If we don't know the width of the wheel and all these other things, we can't give you a useful answer.
The ones from the link would not be a smart choice. In order for those not to rub, you'd have to roll the fenders and deal with negative camber (lots of it) and if you're planning on running 205 or wider tires you can forget it. You'd most likely have to go with 195's or even 185's. Either way, that negative camber would eat them up really quick.
+25 is the absolute lowest I would go with in 15x7. That's if you want to make any sense of it. If you're just chasing a fat lip at any cost, you're on your own...
Modified by GtechPro at 8:13 PM 6/19/2008
Old Jun 19, 2008 | 07:35 PM
bubxba's Avatar
Default Re: lowest offset (GtechPro)
im not completely sure what camber is?and would i ahve to roll the fenders if i didnt lower it over the wheels? as long as i keep it where that one guy with 0 offset does?
Old Jun 19, 2008 | 07:39 PM
bubxba's Avatar
i figured out what camber is, but i dont get how a lowoffset makes it have neg camber i thought that was form lowering cars...is it because with the offset being so low and the whels sticking out farther...it make neg camber?
Old Jun 20, 2008 | 06:20 PM
jmai86's Avatar
What is your reason for wanting 0 / low offset wheels?
It seems you don't have enough knowledge to begin to get into the ordeal of making wheels that weren't meant to fit, fit in our cars. I'd suggest reading up on suspension faqs in the forums as well as using search.
Old Jun 20, 2008 | 08:24 PM
bubxba's Avatar
i dont want that low of a offset i jsut want some deep lip wheels and those happen to be some of my fav. wheels and i jsut really wanted them for my lude....
Old Jun 21, 2008 | 12:34 PM
bubxba's Avatar
ok so i found some enkei oldschool mesh's they are 15x7 +25 offset, this should work right? i think im gnna go ahead and get these i really like them.
Old Jun 21, 2008 | 01:54 PM
GraphiteMW's Avatar
It's your car, get what you like.
Old Jun 25, 2008 | 11:51 PM
GtechPro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubxba &raquo;</TD></TR><TR><TD CLASS="quote">ok so i found some enkei oldschool mesh's they are 15x7 +25 offset, this should work right? i think im gnna go ahead and get these i really like them.</TD></TR></TABLE>
Those will fit.
