where is the coolant bleeder nut?
Re: where is the coolant bleeder nut? (piggydog)
1 find the radiator
2 follow the hose to the thermostat housing. (the place where the lower radiator hose hooks up to the engine)
3 it's on top of the thermostat housing. 12mm bolt with a hole/nipple in the middle. you can't miss it
Re: where is the coolant bleeder nut? (IMHARD2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMHARD2 »</TD></TR><TR><TD CLASS="quote">Or even easier, it's between the distributor cap and the coil. Just had mine worked on...</TD></TR></TABLE>
u mean where the water temperature sensor goes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> powerdbygarrett: u mean where the water temperature sensor goes?</TD></TR></TABLE>
Yes very close to that.
The coolant bleeder screw is #12 in the pic and the coolant temp sensor is #15.
Deon Watkins
01-22-2017 03:14 PM
