Best place to get vaccum for turbo setup?
Im just trying to learn about turboing and everything so please dont get all bitchy. Where is the best place to get vaccum for the BOV? like what line and everything. Also for the wastegate do you connect that to the boost controller and then to the port on the compression housing on the turbo? right? wrong? or is there a better way? Im just trying to learn everyone so dont get pissed off. Thank you.
1 Post
Re: (92prelude23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92prelude23 »</TD></TR><TR><TD CLASS="quote">Okay thank you. Also do you connect the wastegate to the compression housing on the turbo?</TD></TR></TABLE>
Well, what kind of wastegate do you have and did it not come with a diagram?
I have a wastegate that opens up at 8psi. do you this the best way to set this up is to connect the wastegate to the boost controller and then to the compression housing to the turbo.
I have a wastegate that opens at 8psi. the way you set it up is by connecting the boost controller to the wastegate and then to the compression housing on the turbo right..
Yes i do have a external wastegate. but is my setup right or wrong? wastegate goes to boost controller and then to the turbo..which would be the compression housing right?
1 Post
Re: (92prelude23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92prelude23 »</TD></TR><TR><TD CLASS="quote">okay well how do you or would you setup your wastegate?</TD></TR></TABLE>
My wastegate is in my closet right now, but I think you will get much better replies in the forced induction forum. Even searching in there should give you the answer pretty quick...
Re: (92prelude23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92prelude23 »</TD></TR><TR><TD CLASS="quote">Yes i do have a external wastegate. but is my setup right or wrong? wastegate goes to boost controller and then to the turbo..which would be the compression housing right?</TD></TR></TABLE> take pictures
The waste gate and turbo go on this part... The top is for the turbo the bottom is for the waste gate on this picture
your waste gaste looks kinda like this right?
Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">/\/\ He sounds like he just needs to know how to run his vacuum lines....</TD></TR></TABLE> I was thinking he was asking about the waste gate he keeps saying he is putting it on the turbo...
1 Post
Re: (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote"> I was thinking he was asking about the waste gate he keeps saying he is putting it on the turbo...</TD></TR></TABLE>
He said <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">wastegate goes to boost controller and then to the turbo</TD></TR></TABLE>
Just line routing...I hope no one is stupid enough to try to mount the wastegate somewhere on the turbo if it is external
Re: (Hawkze_2.3)
He said
Just line routing...I hope no one is stupid enough to try to mount the wastegate somewhere on the turbo if it is external </TD></TR></TABLE> OH!!!!!! hahahahahaha oops
haha nah im not that stupid but thank you for working with me if i was. well anyways would that set up work... wastegate to boost controller and then to compression housing on turbo... YES or NO..
1 Post
Re: (92prelude23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92prelude23 »</TD></TR><TR><TD CLASS="quote">haha nah im not that stupid but thank you for working with me if i was. well anyways would that set up work... wastegate to boost controller and then to compression housing on turbo... YES or NO..</TD></TR></TABLE>
Since you are unable to take advice or research on your own, I have done it for you.
https://honda-tech.com/zerothread?id=2314835
https://honda-tech.com/zerothread?id=2292034
https://honda-tech.com/zerothread?id=2283106
https://honda-tech.com/zerothread?id=2236094
etc, etc....have some patience and read about the different ways to set it up. It is not YES or NO.
And it's compressor housing, not compression housing.
Civic Racer X 7
05-27-2007 09:07 AM
2LiterTurboSeR
04-19-2006 12:33 PM
