quick cooling question.
Old Jun 23, 2008 | 09:53 AM
whatan00b's Avatar
Default quick cooling question.
Ok i need to change the top radiator hose will i need to drain the radiator? im doubting it sense its so high up. thanks in advance.
Old Jun 23, 2008 | 10:15 AM
snobordboy's Avatar
Moderator
You will lose any fluid that can find its way out, so a partial drain may be good, and have a drain pan under the car for sure! Why not take the excuse and do a full change though? Coolant isn't good forever.
Old Jun 23, 2008 | 10:17 AM
whatan00b's Avatar
Default Re: (snobordboi)
well i just put new fluid in. I just didnt wanna deal with it thats all but ok ill just change it all.
Old Jun 23, 2008 | 10:45 AM
4WSi_guy's Avatar
Default Re: (whatan00b)
just put a big catch pan under the car....when you take off the top rad hose you will only lose what is in the hose and maybe a little from the head. I wouldnt drain it at all. Especially since you just replace the coolant.
Old Jun 23, 2008 | 10:58 AM
Hawkze_2.3's Avatar
Default Re: quick cooling question. (whatan00b)
Yeah, you don't have to drain it all, but to keep things cleaner and make clean-up easier I would drain a good amount from the radiator drain into a bucket. Then you won't spill it everywhere when you take the hose off and you can just poor it back in from the bucket when you're done.
Old Jun 23, 2008 | 11:44 AM
whatan00b's Avatar
Default Re: (4WSi_guy)
killer thanks for the helps.
desi01
Jan 16, 2010 03:28 PM
CRISIS
Jan 6, 2007 10:45 AM
Knight1
Mar 21, 2006 12:24 AM
plusONE jboy
Dec 25, 2004 11:23 AM
LudeChild
Nov 19, 2004 07:58 AM
