Removing old gaskets
Old Oct 12, 2008 | 06:42 AM
kornerk12's Avatar
Default Removing old gaskets
Im putting an oil pan onto a friends 98 lude. What do you guys usually use to clean the old gasket(hondabond) off off the block. Or if your reusing a pan, to clean off the material on the pan ?
Old Oct 12, 2008 | 10:48 AM
TheWalrus's Avatar
scrape off what you can with an old credit card or screwdriver...then spray it down with permatex gasket remover and use a gold (copper?) wire brush...fastest way i found
Old Oct 13, 2008 | 01:55 PM
kornerk12's Avatar
Default Re: (TheWalrus)
that stuff works on hondabond also ?
Old Oct 13, 2008 | 03:24 PM
flyrod's Avatar
Default Re: (kornerk12)
Piece of plexiglass or other hard plastic with a good edge. The problem with power tools is if the engine is in the car it's harder to clean up all the debris scattered everywhere.
Old Oct 13, 2008 | 03:38 PM
kornerk12's Avatar
Default Re: (flyrod)
what power tools do u use ? My whole thing is that im not sure what i can and cant do to the sealing surface ? Like is a wire brush ok or not ? Or steel wool or something idk ?
Old Oct 13, 2008 | 06:24 PM
TheWalrus's Avatar
yes gasket remover works on hondabond and other silicone gasket makers...let it soak for 5 min, scrape and repeat
you can use a wire brush...just brush till the paint comes off and you see bare metal. then use a thin layer of hondabond between the oil pan and the rubber gasket. simple as that
j4s0n1337
Nov 24, 2011 08:31 PM
dgerej2
Jun 13, 2011 12:12 PM
TheOdd001
Feb 10, 2010 12:26 PM
averyvm
Jul 24, 2008 11:36 PM
o d i e e
Oct 4, 2003 08:15 AM
