ABS LIGHT
Old Oct 23, 2008 | 08:01 AM
96-h22a1's Avatar
Default Abs light
i've had this abs light on in my 96 lude for some time now and i need to take the time to fix whatever the problem is i'm more or less clueless as to what the problem is, is there a general issue with these?
Modified by 96-h22a1 at 9:13 AM 10/23/2008
Modified by 96-h22a1 at 9:14 AM 10/23/2008
Old Oct 23, 2008 | 09:27 AM
Matt G's Avatar
Default Re: Abs light (96-h22a1)
Pull codes and see whats wrong...
Disconnect the service check connector from the connector cover located behind the front of the center console. Connect the two terminals of the service check connector with a jumper wire. Turn the ignition switch ON, but do not start the engine. Record the blinking frequency of the ABS indicator light. The blinking frequency indicates the diagnostic trouble code
ChesterNL
Aug 1, 2011 11:35 PM
kit50si
Jan 5, 2008 06:22 AM
Corporation
Aug 21, 2005 08:55 PM
f22suzuka
Apr 21, 2004 10:15 AM
Undercover_Skank
Mar 15, 2004 07:13 AM
