Computer code P0420, catalyst system efficiency below threshold
Old Oct 11, 2008 | 06:39 AM
janek's Avatar
Default Computer code P0420, catalyst system efficiency below threshold
What needs to be repaired or replaced? Car has 110,000 mi.
Old Oct 11, 2008 | 06:49 AM
01 LudeDude's Avatar
Default Re: Computer code P0420, catalyst system efficiency below threshold (janek)
Could be either the cat or the 2nd O2 sensor. At 110K miles, I'd say it's about 50/50 as to which is the problem. I would probably replace them both.
Old Oct 11, 2008 | 06:50 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
cat or o2. you need to have them checked out.
Old Oct 11, 2008 | 08:07 AM
janek's Avatar
Default Re: Computer code P0420, catalyst system efficiency below threshold (01 LudeDude)
Thanks. Where is the o2 sensor? If I try to solve the problem by trial and error, I think it would be a lot cheaper to first replace the 02 sensor. I think that was replaced on my daughters Celica at $60 or so.
Old Oct 11, 2008 | 10:01 AM
Just behind the cat, tapped into exhaust pipe. You are correct, they are about $60ish
Old Oct 11, 2008 | 12:06 PM
janek's Avatar
Thanks for the info. To order the part, what should I ask for?
Old Oct 11, 2008 | 02:35 PM
TruNinja619's Avatar
ahhh... P0420 codes.
Its your Catalytic Converter. replace it.
if you had a problem with either of your o2 sensors, the ECU would store a hard code on it as well.
Old Oct 11, 2008 | 04:50 PM
Default Re: (TruNinja619)
Just examples :
Catalytic Converter - $116.99 http://www.partsamerica.com/pr...Set=A
Secondary O2 Sensor - $ 73.99 http://www.partsamerica.com/pr...Set=A
Old Oct 12, 2008 | 02:22 AM
janek's Avatar
Default Re: (01 LudeDude)
Thanks. You have been most helpful.
Old Oct 12, 2008 | 02:24 AM
janek's Avatar
Default Re: (janek)
Thanks to you all.
Old Oct 12, 2008 | 08:48 AM
bluedlude's Avatar
Default Re: (janek)
umm, i had that error on my old accord and they replaced the EVAP canister.
Old Oct 13, 2008 | 10:07 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 &raquo;</TD></TR><TR><TD CLASS="quote">ahhh... P0420 codes.
if you had a problem with either of your o2 sensors, the ECU would store a hard code on it as well.</TD></TR></TABLE>
not so. The o2 can become biased but the ecu will think that it is functioning normally and that the cat is at fault.
Old Oct 26, 2008 | 05:17 PM
EJ8_Enthusiast's Avatar
check my sig...
in my case I am running *rich* I think (valve stems/seals leaking) and getting a new cat would just cook it so I did this as a substitute to just get the CEL off.
Old Nov 2, 2008 | 03:59 PM
jack_yaj's Avatar
Default Re: (janek)
My 98 Prelude has the same code. I was wondering, if you fixed that problem. What was the problem? The o2 or the catalyst system?
Thank you,
Jack Yang
Old Nov 3, 2008 | 02:25 AM
janek's Avatar
Default Re: (jack_yaj)
Haven't been able to get out the o2 sensor. I assume it has been on the car for the last 10 yrs. I put a lot of muscle on it(albet while lying on my back) but could not get it to budge.
drinksprite
Sep 14, 2018 12:00 PM
2stroke1971
Aug 9, 2016 03:33 PM
miguel11691
Mar 12, 2012 10:09 PM
EF8IGHT
Jan 10, 2006 02:52 PM
LS stretch
Mar 17, 2004 11:57 AM
