engine whine
Old Oct 18, 2008 | 11:56 AM
janek's Avatar
Default engine whine
I had the timing belt, water pump, tensioner replaced because the engine had 100,000 mi. I heard a whine that had not been there before and questioned the mechanic.. The mechanic said the whine was there because he set the timing belt tight and that it would loosen up, break-in, in a short time. 10,000 mi. have gone by and it's still there. Comments please.
Old Oct 18, 2008 | 01:22 PM
lrayford's Avatar
Default Re: engine whine (janek)
be for my frist jdm h22 was sawped from my friends wrecked car i bought from him into my prelude. it made a wineing nose. i had the balance shafts removed and blocked off the space where they ued to be when i had the motor swaped from my new wrecked car into my good car ta daaaaah the wineing went away.
maybe try replaceing or removeing ur balance shafts. thats where my noise came form
Old Oct 19, 2008 | 03:24 PM
prelude_h22vtec's Avatar
my timing belt whined pretty loud for months after i replaced it, but it turned out fine. i wouldnt worry about it.
either that, the guy installed a supercharger and didnt tell you!!
Old Oct 19, 2008 | 03:27 PM
vinuneuro's Avatar
If it's whining, the belt is too tight. What engine is this?
Old Oct 20, 2008 | 11:42 AM
Speedra500's Avatar
Default Re: engine whine (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">If it's whining, the belt is too tight.</TD></TR></TABLE>
I've seen this happen to a few people before, I'm going to guess you've got an H23 for F22, tell him to loosen it up some and that should fix the problem
Old Oct 20, 2008 | 03:10 PM
MazdaSpeedster's Avatar
Default Re: engine whine (Speedra500)
the belt is too tight. also have him adjust the valves
Old Oct 20, 2008 | 04:57 PM
IMHARD2's Avatar
Default Re: engine whine (MazdaSpeedster)
I just did pretty much the same to my lude and I took it back to my mechanic too, and he said the same thing. B/c the belt will loosen up some, so that muthaf***a is tight!! But yea, don't worry,, just enjoy the sound!
Old Oct 21, 2008 | 04:58 AM
94vtecmn's Avatar
Default Re: engine whine (IMHARD2)
Mine whined for about 10-15k before the whine went away. The belt only lasted about 80k, but that's with a Crower valve train, which will put a lot more stress on the belt. And, I never adjusted it, with a manual tensioner. Got to keep up on that . You'll be fine.
RandyOo
Dec 26, 2013 02:35 PM
BLKFLSH
Dec 20, 2011 11:30 AM
down_the_hatch
Apr 28, 2011 11:41 AM
dynamyks
Aug 12, 2005 06:38 AM
Shoobie
Apr 13, 2005 11:53 PM
