driving with check engine light on
Old Oct 18, 2008 | 11:44 AM
janek's Avatar
Default driving with check engine light on
I was on last week about the check engine light. Most suggested it was the 02 sensor or the cat. Since it was cheaper to replace the second 02 sensor, I tried it this weekend. I couldn't get it off using 2 hands and a breaker bar. I would guess it is the original, 10 yrs old.
What happens if I drive the car with the light on?
Old Oct 18, 2008 | 02:39 PM
ezra76's Avatar
Default Re: driving with check engine light on (janek)
Nothing happens unless the problem becomes a danger to the engine, then it will blink and go into a limp/derate mode, limiting the RPM's. See if any parts stores will check the code for you. If it's a 5th gen. you plug it in down on the passenger side. The port is located under a panel covered in carpet. It took me a little while to find mine, the parts store guys didn't' know where it was. Get the code and they should have a table to tell what it means, or just write it down and ask here.
There is also some way to jump it with a paperclip and get a readout. I've never tried it before. I drive with my CEL on, can't get rid of it. I've got a transmission code coming up but nothing seemingly wrong at all with my trans.. Get it checked and find out what it is for sure, that's what it's there for.
Old Oct 18, 2008 | 06:18 PM
cfran55's Avatar
Default Re: driving with check engine light on (ezra76)
i have a cel due to a test pipe. also there is a tool that you can rent for free at autozone with a deposit that is designed to take out the 02 sensors
prejdmlude
Sep 27, 2009 11:10 AM
patpeery
Apr 4, 2008 02:40 PM
ph0shizzle
May 13, 2006 08:36 PM
eg686
Apr 18, 2003 01:01 PM
97gSrkId88
Mar 20, 2003 11:06 PM
