engine idle problems!!! please help
Old Oct 21, 2008 | 04:03 PM
CRX30436's Avatar
Default engine idle problems!!! please help
whats goin on everybody?? here is my problem i just put an h22a4 in my integra and its idleing really [freak]ed up!! when i crank my car up it will idle low so when i adjust the throttle cable it will pick up some, then when i give it a lil bit of gas the rpm will jump to about 3000 and stay there but then when i tap the gas pedel slightly it will idle back down to about 700-1000rpms or some times lower then that???
what iv done i cleaned the tb, checked the vacuum lines and caped'em, replaced the fuel filter, tps sensor(it came off a d-series engine).. can someone plase help
Old Oct 21, 2008 | 07:55 PM
crawlin's Avatar
Default Re: engine idle problems!!! please help (CRX30436)
why would you cap the vaccum lines?
Old Oct 21, 2008 | 09:51 PM
97ludedude's Avatar
you need to leave slack in your throttle cable. do not adjust your idle that way it will freak the computer out. search in the faq there is a post that tells you everything to check.
Old Oct 22, 2008 | 12:52 AM
superturboprelude's Avatar
Default Re: engine idle problems!!! please help (97ludedude)
is there any check engine lights on? also yea do not tighten teh cable all the way leave it some slack. also youre Tb cable might be sticking too or the throttle cable plate might be sticking spray some wd 40 on the throttle cable plate.
Old Oct 22, 2008 | 02:51 PM
crawlin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX30436 &raquo;</TD></TR><TR><TD CLASS="quote"> then when i give it a lil bit of gas the rpm will jump to about 3000 and stay there</TD></TR></TABLE>
Try doing this then when the rpm's stay around 3k or so trying pulling the gas pedal back up towards you. If you do this and it moves back some and the idle drops down most likely the cable or throttle plate is getting hung up somewhere.
Old Nov 2, 2008 | 08:39 PM
CRX30436's Avatar
sweet!! thanks alot guys i will do all of the above and keep you informed.
91grape
Aug 19, 2012 06:22 PM
dougsunny
Jul 19, 2010 06:00 PM
emooheo
Mar 23, 2007 02:34 PM
Spence
Apr 24, 2006 08:15 PM
shooitzlinh
Jan 8, 2005 09:52 PM
