93 SI stalls while engine is cold.
Old Oct 22, 2008 | 11:49 AM
rbflurry's Avatar
Default 93 SI stalls while engine is cold.
Hey guys hopefully you can help. I did look around with the search button with no help. anyways i have a 93 si i just dropped a h23a into and with the weather getting colder here in Maryland on colder mornings the car starts but then immediately stalls. it will do this until the engine warms up a bit.
Any ideas? thanks
Ryan.
Old Oct 22, 2008 | 03:45 PM
mattsnooz's Avatar
Default Re: 93 SI stalls while engine is cold. (rbflurry)
sounds exactly what happened to me. Try changing the Coil pack (ignition coil).
Secondly, I found that it could also be that moisture/condensation was getting in my distributer with an aftermarket cap. I put a genuine honda one on with a new seal.
I believe in your situation its the coil pack. Even if the coil's resistance checks out, my car would fire up no problem, but when the circuit kicked over to the run coil it dies out. After I start it sometimes two or three times it stayed running.
I'm guessing your car stalls out unless you really mess with the throttle(gas) correct between 1-3 times and usually only in the mornings??
jluicifer
11
May 29, 2016 02:57 PM
joshy2121
12
Jan 13, 2012 04:43 PM
itr1235
Aug 8, 2005 06:32 PM
93LudeDude
May 30, 2005 08:58 PM
Amadeus
Oct 27, 2002 07:38 PM
