Nub Question
Old Dec 6, 2009 | 09:19 AM
Dabrybry's Avatar
Default Nub Question
Sry about the nub'ishness of this question but I think my clutch is failing in my 95. I was gonna try to see if maybe if just needed some manual tranny fluid though, but I'm not sure which reservoir is used for trans fluid. The ones I think I have identified correctly are the brakes master cylinder, power steering and brake fluid ones. Where is this thing located at? Is it as simple as unscrewing a cap somewhere and pouring some in? Or am I going to have to remove the passenger wheel and fiddle with drain and fill bolts? Any help would be greatly appreciated.
Thanks,
-Bryan
Old Dec 6, 2009 | 10:13 AM
street_ride14's Avatar
Default Re: Nub Question
^^ Yup, there is no reservoir for manual transmission fluid. It's quicker than you'de think though.
Just make sure to have 2 quarts of Honda MTF and new fill and drain washer to use.
Steps ...
Remove passenger tire,
remove fill bolt,
remove drain bolt,
drain all fluid out,
replace drain bolt with new washer,
have 2 quarts of Honda MTF ready,
stick a hose throught the engine bay passenger side to your fill hole,
attach funnel to the end that you will be pouring through,
lower car ( with tire off, just use regular scissor jack ) making sure car is even,
pour MTF into funnel,
use all 2 quarts - a little fluid would leak out through the fill bolt near the end - this signals that you're done - do not pour anymore,
remove hose from fill hole,
jack car back up,
replace fill bolt with new washer,
replace tire,
lower car.
Enjoy.
Mike8ike
Transmission & Drivetrain
Jul 30, 2013 05:20 AM
Pilot King
May 21, 2011 04:31 PM
jimmy408
Sep 11, 2008 07:48 AM
pnoipj89
Apr 16, 2008 05:43 AM
Re3irth
12
Sep 1, 2004 02:58 PM
