cold start issue
Old Dec 6, 2009 | 09:09 AM
313hitman's Avatar
Default cold start issue
I have a 92 lude h22a swap. durring the summer months it starts and runs perfect but every winter I it start it and want to shut off unless you hold the gas at 1500 rpm for at least 30 seconds. also I noticed that if I hold the clutch in its less likely to shut off.
Old Dec 6, 2009 | 10:19 AM
street_ride14's Avatar
Default Re: cold start issue
It's spark or fuel related. Do a tune-up and see if that helps. Replace fuel filter, and spark plugs/wires for sure.
Old Dec 6, 2009 | 10:28 AM
amboyeg's Avatar
Remove the idle air valve then spray TB plate cleaner inside and let it sit for a couple of hours so it brakes down the carbon.You should be fine after that also clean TB as well.
ddavanzo92
Mar 6, 2014 06:18 PM
MilFhunter001
Jun 1, 2010 06:55 AM
thecruzs2007@yahoo.com
Sep 22, 2009 07:41 PM
dividedas1
Mar 16, 2009 08:13 AM
myprelude
Mar 27, 2006 06:41 PM
