Compression figures in psi
Old Nov 30, 2009 | 05:11 PM
ace8's Avatar
Default Compression figures in psi
Hi all, What are the figures in psi should be for a 10.6:1 and 11.0:1 comperssion ratio?
Old Nov 30, 2009 | 05:28 PM
NirVTEC's Avatar
Default Re: Compression figures in psi
1. 180 psi
2. 179 psi
3. 179 psi
4 180 psi
That^^^ was just posted from a 10.6:1 JDM H22A
I always thought it was more about the consistency across the 4 cyls NOT the actualy number.
I'm not sure that EVEN compression numbers mean your engine is OK though. My shop prefers the leak down test.
Old Nov 30, 2009 | 06:05 PM
Acidcrakker's Avatar
typically anything below 150 means your engine is just about toast
Old Nov 30, 2009 | 06:18 PM
jlude90's Avatar
Compression and leakdown both have their place.
Old Nov 30, 2009 | 06:42 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
^ Care to explain that a little more?
Old Nov 30, 2009 | 07:34 PM
If you know there functions there is no need to explain.
Compression test just tells you your compression
Leak down tells you were you are leaking compression from
Old Nov 30, 2009 | 09:02 PM
ace8's Avatar
Guys, Im having the "mayo" in the radiator despite having
230,210,210,230.My compression is about 11.0:1 but I do not know the actual psi value I should be getting.
Old Nov 30, 2009 | 09:18 PM
Your PSI value should be about 5 percent within each other.
Your figures are 10 percent within each other.
Old Nov 30, 2009 | 09:35 PM
ace8's Avatar
Yeah going to replace gasket again and some skimming.
Old Dec 1, 2009 | 12:35 AM
91lude4ws's Avatar
with those figures i would guess you have a blown head gasket in between cylinders 2-3. that would explain the "mayo" in your radiator.
Old Dec 1, 2009 | 03:58 AM
PirateMcFred's Avatar
My old 11.2:1CR H22 made 240psi across the board at 500' elevation on a cool day. It makes a difference which compression tester and cams you're using too.
Old Dec 1, 2009 | 07:55 AM
I have actually heard of someone doing a fresh h22 rebuild and getting 300 psi in each cylinder.
Apparently brand new motors have higher psi until they are broken in
Old Dec 1, 2009 | 03:15 PM
TheJGB3's Avatar
According to the HELMS 135PSI or above is fine. But like NirVTEC said what's important is the consistency across all four cylinders.
Old Dec 1, 2009 | 04:16 PM
NirVTEC's Avatar
I just remember SKEETER @ Newcastle Honda freaking out when he did the Compression test on my JDM H22A when I was out there........
I guess he was a little surprised to the results as compared to your run of the mill F22'd Accord.
michaelcal12
Honda Civic (2001 - 2005)
Dec 13, 2012 07:49 AM
puma2132
Feb 8, 2009 02:37 PM
EG6 Love
Feb 15, 2008 05:06 PM
6E LUDE
Nov 10, 2005 05:38 AM
brent_G
Oct 12, 2003 12:15 AM
