Please Help!
Old Dec 20, 2009 | 02:44 PM
young_tuner's Avatar
Icon3 Please Help!
Me and a friend just installed an msd ignition blaster coil pn# 8207 it started up and then the tach was just bouncing up and down, and i gave it gas and it died, we checked the voltage and it is still producing voltage to the coil, we then plugged in the stock coil and all it does is crank. It doesn't start, we also checked the fuses they are still good, what should i check?
Thanks,
Ian
Old Dec 20, 2009 | 03:18 PM
su8854's Avatar
Default Re: Please Help!
plugs r good?
su8854's Avatar
did it work with the stock coil before and it stopped working after you tried to use the msd? im using the coil and the box its been working fine
Old Dec 20, 2009 | 08:23 PM
Stock coil did work before, the ignition control module had to be replaced now the car runs but now the tach doesn't work, any ideas? The car is hooked back up to the stock ignition coil also.
Thanks.
Old Dec 21, 2009 | 07:27 AM
su8854's Avatar
check if ignition wires. see if they are sitting on a coolant line or the thermostat. that happened to me before which made my cluster go all crazy. make sure no wires is leaning on a hotspot
Old Dec 21, 2009 | 08:13 AM
Will check! Thanks, will update!
Old Dec 21, 2009 | 10:54 AM
no wires touching.
Old Dec 21, 2009 | 11:38 AM
starbai's Avatar
wish i had an answer or a way of helping you but i'm interested in the answer so subscribed.
Old Dec 21, 2009 | 12:58 PM
I think there was a miss matched wire when my friend hooked up the ignition control module it was dark so he couldn't see much of what he was doing and i wasn't around. So i have to look at it again, will keep this thread updated.
Old Dec 21, 2009 | 01:00 PM
NirVTEC's Avatar
Good choice....its worth tons of horsepower......
Old Dec 21, 2009 | 01:05 PM
wow dude, are you being sarcastic or what.. i'm putting this coil on only to fix my problem not for a hp gain.
Old Dec 21, 2009 | 01:06 PM
NirVTEC's Avatar
Good. Although I like OEM for anything possible.
Old Dec 21, 2009 | 01:07 PM
Well the OEM part cost like $80 this only cost $46.. and money is tight.
Old Dec 21, 2009 | 03:02 PM
q16racer's Avatar
3 basics.
you need fuel, fire and compression for an engine to start. You are missing one or two. Find which one you are missing and determine the ways it would stop working. Just because you have fire going to the coil does not mean your igniter is firing the plugs or that you are getting fire to the plugs.
OEM coil > MSD coil.
Your 49 dollar coil and unknown wiring job just cost you more money to fork out for an igniter (cheapest option). Good job trying to skimp.
________
IOS GAMES
Old Dec 24, 2009 | 08:03 AM
Originally Posted by q16racer
3 basics.
Well first off i didn't wire it, my friend wired it, and then it didn't work it ended up burning out my ignition coil module, and my friend replaced it because he felt as if it was his fault, and it cost $113, so everyone is saying i should just send this msd coil back and just get a new stock one? And thanks for being a complete ******* Q16..it is so common to find this in Honda Guys, i'm not sure why either. This forum is here to help each other out, to offer the knowledge you know for the guy that doesn't know it, not to put them down and step on them...
redlinez_r_us
May 28, 2010 12:05 PM
IntegR
Dec 19, 2006 05:24 PM
Rodzknight
Jul 3, 2006 01:02 PM
roterx7
Apr 1, 2006 05:23 AM
GTEater
Jun 25, 2001 01:01 PM
