to those of you who are having problems with the skunk2 throttle body sticking, weird idle problems and all that. its because if you made your own gasket or dint use the stock skunk2 one it gives you alot of problems. no matter how nice of a gasket i made it never made a differance. the stock skunk2 throttle body gasket has another hole that nobody knows about which i have put a red dot on it. just punch a hole where the red dot is and it will fix everything. also use something that tells you your throttle position to set your tps that will prevent some sticking. i hope this helps as i had problems with this for MONTHS
EjSex
15
Aug 11, 2010 12:09 PM
