Help! Car Shake When Accelerating
Old Jan 1, 2010 | 10:51 AM
crazi3ge3's Avatar
Default Help! Car Shake When Accelerating
I just bought a 95 prelude with a jdm h22. When I start picking up some speed, the car shakes a little when i accelerate. But when i drive at a normal speed it doesn't shake, only when accelerating. The owner before me said the car has energy motor mount inserts in it also with a lighter flywheel. Could one of those be the problem?
Old Jan 1, 2010 | 11:02 AM
jdmboss's Avatar
Default Re: Help! Car Shake When Accelerating
shaking as .... hesitating ? maybe sparkplugs... or something in your ignition system.....
Old Jan 1, 2010 | 11:37 AM
crazi3ge3's Avatar
no nothing like that i think the engine is fine. streering wheel shaking and the whole car shaking sorry about that
Old Jan 1, 2010 | 11:49 AM
prahjekt's Avatar
Mine is doing the exact same thing. I had it looked at and it appears I need to replace an axle. That could be your problem.
Old Jan 1, 2010 | 11:51 AM
crazi3ge3's Avatar
did u replace both side? did u buy an aftermarket one or just oem?
Old Jan 2, 2010 | 09:57 PM
dRiv3R's Avatar
Check your ball joints! Park someplace flat and point your wheels perfectly straight ahead then pull on your wheel at the top HARD. If there is any play replace your upper ball joint. I had the exact same problem. It could very well be the axle but this is more commonly a ball joint issue.
Old Jan 3, 2010 | 10:18 AM
Enzo15's Avatar
I had shaking as well, altho it was at all times of driving, turns out the wheels needed to be balanced. After I got them balanced it still shakes a tiny bit, but the steering joints are a little loose, and prolly should be replaced on mine :D
Old Jan 3, 2010 | 10:53 AM
kamranm3's Avatar
might be the wheels arent balanced. This happened to my friends maxima and that was the problem
Old Jan 3, 2010 | 12:52 PM
crazi3ge3's Avatar
the upper and lower ball joints has been replace, and just got new rims and tires 2 month ago. i think it's the cv axle i might have to change it. how do i no what side is bad??
Old Jan 3, 2010 | 01:02 PM
Mr. Winky's Avatar
Physically look and see which one looks worse? idk.. thats a good start. I would say the one that has a torn cv boot or is slingin grease could be the culprit.
If neither one looks damaged or worn out.. then Idk.
Old Jan 3, 2010 | 01:15 PM
crazi3ge3's Avatar
both side cv axle looks brand new. not even a rip boot. i think i might take it to a tire shop and ask them if they can check it out
Old Jan 3, 2010 | 01:40 PM
mrharmonic's Avatar
i know this is a lude page but the same thing is happoning to me. i know its the axel im going to get them rebuilt tomorrow driver side on mine
Old Jan 3, 2010 | 05:13 PM
prahjekt's Avatar
Sorry, can't help you out there. My driver's side boot is torn wide open, so it's easy to figure out the problem.
Old Jan 3, 2010 | 06:22 PM
313hitman's Avatar
my rim had a couple dents that causes my shakes, plus it was really bad before I changed my ball joints.
Old Jan 12, 2010 | 06:53 PM
dRiv3R's Avatar
I just though of something. Check to make sure your CV axle nuts are tight. If the axles were recently replaced then they might not have been tightened all the way. Also check that the ball joints are tightened as well. If they were replaced recently then the also may be loose. If it's only shaking during accel then it strongly points to axles/balljoints
Old Jan 12, 2010 | 07:41 PM
X-bb4lude-X's Avatar
i had the exact same problem right after i lowered my lude
Old Jan 13, 2010 | 03:48 AM
ben_deez's Avatar
check your balance shaft belt......(its the small timing belt looking thing)
check motor mounts too
Old Jan 13, 2010 | 05:54 AM
darkestfenix's Avatar
did you get an alignement after you dropped?
Old Jan 13, 2010 | 09:54 AM
Targa250R's Avatar
be professional
In the vast majority of cases, a vibration only upon acceleration is caused by a bad inner CV joint. Most of the other possible causes listed here - such as a bent wheel or various suspension problems - would be evident all of the time, not just during acceleration.
Even if the axles look "new," they may still be faulty, especially if they are remanufactured axles from a chain parts store. I've seen plenty of those click and vibrate straight out of the box.
Old Jan 13, 2010 | 06:41 PM
tensaiwung's Avatar
I have that problem also and idk what it is? thanks ill check
Old Jan 13, 2010 | 07:01 PM
crazes's Avatar
Moderator
easy way to see if your axles are bad in go to an open parking lot or somewhere you have space. turn your steering well full left and acclerate, if you here clicking its ur axles... and the turn to the right all the way.. if you here nothing isn't ur axles.. also simple thing make sure your lug nuts are all still tight. sometime shops tighten the lug nuts in a circular style instead of a star which evenly tq all of them.
Old Jan 13, 2010 | 07:10 PM
Targa250R's Avatar
be professional
You will only get a clicking noise if the problem lies with an outer CV joint. Inner CV joints are of a different design and will not click when they are bad. Inner CV joints also don't articulate much if at all when turning the steering wheel. Thus, your "test" will only detect a faulty outer joint, not a faulty inner joint.
Old Jan 13, 2010 | 07:19 PM
shietzitzkien's Avatar
axles
Old Jan 14, 2010 | 12:17 PM
1grex's Avatar
inner axle joints
CrxGrin
Jan 20, 2013 08:53 PM
Taimaishuuyo
Transmission & Drivetrain
Jul 12, 2011 03:10 PM
freezy
11
May 9, 2011 02:19 PM
therealslickric
Oct 12, 2010 06:26 PM
