transmission problem
Old Dec 25, 2009 | 06:29 AM
Apex1972's Avatar
Default transmission problem
I had 3rd gear replaced in my car a few years ago. Now recently 3rd gears starts to grind slightly again. Its only when shifting from 2nd to 3rd. When I downshift into 3rd from 4th,its OK.Is there also a problem with 2nd gear synchro? I am about to get the transmission worked on again and I don't want to leave anything wrong again.
Old Dec 25, 2009 | 08:16 AM
minilogoguy18's Avatar
Default Re: transmission problem
I'd get all of the synchro's replaced this time around, if it has a lot of miles on it and 1 set went wrong and now a second they all might be on their way to going out.
Old Dec 26, 2009 | 02:55 AM
drew1987's Avatar
your shelves might also be shot so it makes your snychros get worn out....the shelves have to be very pointed like the synchros...so some of the teeth are round then there no good....
Old Dec 26, 2009 | 05:43 AM
Apex1972's Avatar
Originally Posted by drew1987
your shelves might also be shot so it makes your snychros get worn out....the shelves have to be very pointed like the synchros...so some of the teeth are round they there no good....
sorry, but what are shelves?
Old Dec 26, 2009 | 07:13 AM
jnv255's Avatar
The way you drive a 5 speed, I bet it don't work, lolz.
Old Dec 27, 2009 | 11:55 PM
drew1987's Avatar
shelves are what controls the tranny to go into gears so it slide into the synchro...when a synchro goes bad most likely that the shelve also went bad...
jrdc5r
Transmission & Drivetrain
Feb 19, 2019 10:57 AM
integraboi1010
Mar 5, 2007 09:14 AM
hondafrk505
11
Jul 6, 2006 05:21 AM
soundcheck187
Jul 15, 2005 04:49 PM
