how-to: h23vtec
Old Nov 20, 2002 | 01:23 PM
h23vtec_dc2's Avatar
Default how-to: h23vtec
anyone know wussup w/ this swap. i be hearing that they turn out bad, runs like ****, too much problems. anyone know how to do it right or know of a site that shows wussup? let me know.
thanks
Old Nov 20, 2002 | 01:28 PM
satan_srv's Avatar
Default Re: how-to: h23vtec (mugenb18c5)
Please search.
By the way mine is busted if that gives you an idea of how reliable it is...
Old Nov 20, 2002 | 03:18 PM
user 9782082308's Avatar
Default Re: how-to: h23vtec (satan_srv)
What broke???
Old Nov 20, 2002 | 04:25 PM
satan_srv's Avatar
Default Re: how-to: h23vtec (racerx)
What broke???
The crankshaft!
Old Nov 20, 2002 | 06:40 PM
How did you manage that?!?! Isn't that thing forged? What do you think caused it?
Sorry bout all the questions! I've been wanting to try this for a while, but I keep getting different answers. My logic tells me that it should work cause Honda actually built one for the Accord R. Everybody keeps referring to the r/s ratio but theres ways around the extra wear. Plus, r/s ratios aren't the only thing figure you can rely on to know wheather or not an engine will work.
Old Nov 20, 2002 | 06:56 PM
CD8's Avatar
CD8
2point6 has a complete write up on the frankystien h motor on his website http://www.collectiveracing.net
its in the tech section... you may have to register to view it.
[Modified by exaccord, 7:57 PM 11/20/2002]
Old Nov 20, 2002 | 06:57 PM
yea.. let me know, exactly what you would need to do
Old Nov 20, 2002 | 06:59 PM
satan_srv's Avatar
I dunno man it's not opened up yet...but it's definitely fucked!
The H23 VTEC was not in the accord R, it was in the accord wagon.
What you don't know about the Accord H23 VTEC is what the actual internal of the H23 block is. Fact is, this block is likely NOT much like the H23 block which was discontinued about 4-5 years before the H23 VTEC came back in the wagon. I would suggest Honda did a couple of things to improve the Rod/Stroke of the engine. I'm adding another post about my F20B rods that should shed some light on what they did.
The short form of my theory is that the rod journal is actually smaller than an H22a in order to run a longer rod.
Old Nov 20, 2002 | 07:48 PM
KS-R's Avatar
Hm... I just remembered something.. You said your crank broke.. Was your balance shaft belt hooked up? Cause I remember reading on h22a.org that one of their motor's crankshaft broke cause of the balance shaft.. Wonder if that could be related. Just a thought.
Old Nov 20, 2002 | 09:24 PM
satan_srv's Avatar
Default Re: how-to: h23vtec (KS-R)
Really? That's very odd....well the balancer belt was hooked up...but it was all out of whack once the timing belt skipped...
Old Nov 26, 2002 | 10:12 AM
anyone else? what parts you need to complete, etc???
Old Nov 26, 2002 | 10:29 AM
2point6's Avatar
http://www.collectiveracing.net/cgi-...=ST;f=11;t=107
fltblkEFhatch
Sep 19, 2009 07:39 PM
KStuned
Jan 8, 2009 06:11 AM
Cidone
Feb 8, 2005 02:51 PM
Martaigne
Jul 23, 2002 10:41 AM
