Drag radials on base rims........
Should i use drag radials with the base rims or get other rims to run on the track? Im running a good shot of NOS and want to do some damage on the track.
Re: Drag radials on base rims........ (ChargedLude97)
225/50's are some tall *** tires....didn't that cost you top end??
EDIT: my thinking is backwards...they would cost you acceleration...
[Modified by dsludefosho, 11:49 PM 11/18/2002]
I use 205/45/16 555r's on my stock rims. The hooked up great when I had bolt ons, seem to hook up decently with the supercharger. ChargedLude97, what kind of times have you run in the 1/4 mile?
[Modified by bkw97lude, 3:40 PM 11/19/2002]
Re: Drag radials on base rims........ (bkw97lude)
Well with a 2.3 60ft from wheel hoping I got a 14.4 at 4800 elevation. not really that good...on the next run I had a better launch but blew 2nd gear, fixed that. Went back to track and broke stock diff and axle(input shaft) with alot of other things, now that's fixed and have a lsd but the tracks closed.
[Modified by ChargedLude97, 3:17 PM 11/19/2002]
AllMotorITR
01-08-2002 10:17 AM
