Vacuum Leak Testing
Old Nov 25, 2002 | 08:59 PM
fe519's Avatar
Default Vacuum Leak Testing
Hey people... I have a h23 engine and want to know how do you guys check for vacuum leaks. Also, how many hoses are there to check and where are they located. Thanks for your inputs.
Old Nov 25, 2002 | 09:02 PM
CBR's Avatar
CBR
Default Re: Vacuum Leak Testing (fe519)
It depends. Why do you think you have a vacuum leak?
You start by pinching off vacuum lines.
Old Nov 25, 2002 | 09:10 PM
fe519's Avatar
Default Re: Vacuum Leak Testing (ChurchBoyRacer)
hhmm... because my idle is jumping erratically
where does the vacuum line run from and to?
[Modified by fe519, 6:11 AM 11/26/2002]
Old Nov 26, 2002 | 02:38 AM
SuperSH's Avatar
They run all over your engine bay. Almost everything that comes off your intake has vacuum on it. You can use carb cleaner spray or water in a squirt bottle (which is safer) when spraying carb cleaner the idle will surge when you find a leak or stumble when you use water. Dont forget to check the vacuum resivour.
Old Nov 26, 2002 | 11:08 AM
Niozoin's Avatar
Default Re: Vacuum Leak Testing (SuperSH)
My 2 favorite meathods of finding vaccume leaks are a smoke machine and propane search.
The smoke machine pumps out a Vapor (lemon scented) I usually plug the line into the brake booster vaccume line and let it pump away.....any leak will start pouring out this vapor (smoke) and is pretty easy to find with a good light
The Propane search need the engine running.....and by using a propane bottle with a little wand on it (using a very low flow of propane) startmoving the end of the wand by any connectors you can see....if the idle increases....you have found a leak (it leans out your A/F Mixture)
Both meathods work well...and if you can't find it with one....the other usually works.
Old Nov 26, 2002 | 11:32 AM
fe519's Avatar
Default Re: Vacuum Leak Testing (Niozoin)
can you tell me where can i find the smoke machine or the propane? Also, if I pump it from the brake booster vacuum hose, it will check the whole car for any vacuum leaks?
Old Nov 26, 2002 | 01:13 PM
BoostedH23a1's Avatar
Propane
00gs-r
May 19, 2007 11:21 PM
tigueremalo
Apr 14, 2006 11:37 AM
diymarc
Jul 28, 2004 09:09 PM
xXsarcasmXx
Jul 14, 2002 11:26 PM
