injector question
Old Nov 23, 2002 | 08:19 AM
GruvyTune's Avatar
New User
Default injector question
waiting on my helm manual for my 2001 SH
what are the stock injectors flow rate? i did a search and found no relieable answer. is there a resistor box? i didn't see one around anywhere. so are they saturated or peak and hold?? perhaps i didn't look hard enough for a resistor box. will rc injectors swap into the stock clips and will i need a different size o-rings for the manifold inserts?
thanks
Old Nov 23, 2002 | 09:03 AM
sharkcohen's Avatar
Default Re: injector question (GruvyTune)
thanks
Stock injectors are 290 cc. There is no resistor box, they are saturated. You will need a resistor box to run peak-and-hold. The stock injector clips will not fit the RC injectors. When you swap the injectors, you can use the stock "soft" manifold washer while leaving out the "hard" washer (also suggest purchasing new "soft" washers rather than reusing the used ones, just in case the used ones leak on you).
[Modified by sharkcohen, 6:17 PM 11/23/2002]
CivSiClone_96
Dec 20, 2009 05:52 PM
DrivinVtec
Sep 17, 2007 10:08 AM
Enzo Speed
Aug 21, 2006 03:14 PM
adnoh
Jun 9, 2004 09:59 PM
Hoodwinked
Dec 13, 2003 12:33 PM
