E-brake problem light problem. . .
Old Dec 30, 2002 | 12:29 AM
ponzarelli's Avatar
Default E-brake problem light problem. . .
sup everybody...i got a problem with the e-brake light coming on...does anybody know what that means?....it usually comes on when the car is really cold and comes on when i hit the brakes every now and then...
Old Dec 30, 2002 | 04:11 AM
ViruX's Avatar
Default Re: E-brake problem light problem. . . (ssr h22)
check and make sure the e-brake handle is totally down.....i know if mine is even up a lil bit, that light comes on....
-Vi
Old Dec 30, 2002 | 04:32 AM
rjr162's Avatar
Low brake fluid. Top it off and it should go away. You can also tap the top of the cap as sometimes the float will get stuck giving you that light. Cheers
Old Dec 30, 2002 | 09:51 PM
Jago's Avatar
Default Re: E-brake problem light problem. . . (rjr162)
You have a bad brake master cyclinder sensor
It's not a big deal it just makes the light come on.
Old Dec 30, 2002 | 10:42 PM
KiDwItHaReDlUdE98's Avatar
Default Re: E-brake problem light problem. . . (Jago)
check your brake pads
JDMmovement
Apr 26, 2008 08:50 PM
btman
Oct 12, 2007 06:11 AM
jravensc
Aug 6, 2007 01:42 PM
intech
Nov 17, 2005 02:44 PM
sullycrx
Nov 16, 2005 09:48 PM
