Engine harness help
Old Oct 23, 2010 | 10:45 AM
Prudz_lude's Avatar
Default Engine harness help
So guys, the guide that I tried to use wasn't much help. I still have no clue what this yellow/green wire is for. I know vtec is the most logical answer, however it appears my vtec oil pressure sensor, solenoid sensor etc are all intact. I have been told it is for the ignition since there are actually two green yellow wires on the harness. Still for the life of me can figure out where it goes. I am assuming it is just missing a connector off the end of it.
This is where it is running off of. I looked at all the wire colors and can't for the life of me figure out what plug this is.
I also have another issue. I had 3 broken connectors on the harness when I picked it up. I swapped over the connectors from an old h23 harness I had kicking around. The map sensor along with 2 others were swapped. Now I depinned them and kept them in the right orders. However, on the last two wire connector I was not paying much attention, depinned it and realized I didn't write down the order the two wires were in. I am unsure which wire is on the top or the bottom. Top being the part where the clip is pushed down to unlock the connector. These two wires are yellow/black and blue/black. Does anyone know what connector this is for? Something I don't need?
Hopefully someone can help me out. The harness is all finished, just needs to be installed after I figure out these two issues.
Old Oct 23, 2010 | 11:26 AM
Kronn 98SH's Avatar
Default Re: Engine harness help
Which engine/chassis? Which plug #? Which guide?
Asmooh
Apr 23, 2014 04:32 PM
AW
Jun 17, 2008 12:55 PM
NatedoggAZ
Nov 8, 2003 03:59 PM
