TPS and Hondata S300...
I was told that I could get the readout of the TPS sensor via laptop connected to the S300 but I couldn't see this anywhere only throttle %. Asking cause I just want to make sure the sensor is set right and getting back there with multimeter probes is kinda a PITA. Thanks for any advice.
Re: TPS and Hondata S300...
Thanks, thought it would show me the same readout I would get with a multimeter like 0.5v at idle and 4.5v at WOT. It was actually spot on reading 0% at idle, I just wanted to rule this out as the slight hesitation I seem to be getting at like 2-5% throttle while cold but when warm it isn't there. Could be from the Euro R mani and lack of FITV even though the basemap from phearable runs the car great otherwise.
I actually set the TPS just by hitting the throttle and turning it until I got the best response, easier than people think without a multimeter.
Did you ever find out what the issue was? I actually am running the same setup on a used car I just purchased and I am having the same exact issue. I recalibrated with the s300s throttle interpolation readjustment because it was reading I think like 1% closed and 92% wide open and it slightly got better but it is still present. I know this is a dead thread but I would really appreciate any feedback. Thank you.
