Replace or adjust valves?
Old Oct 13, 2010 | 05:46 PM
Prelude209's Avatar
Default Replace or adjust valves?
sup guys this aint my video but my h22 is making the same ticking noise that goes throughout the entire video. im not talking bout the deep one towards the end but the high pitch ticking sounds like a diesel sorta lol.
http://www.youtube.com/watch?v=oB0jKkmNs3g
just wondering if valves could be bent or just need adjustment? the oil im using currently is mobil 1 10w30 not sure if that matters btw...
Old Oct 13, 2010 | 06:10 PM
AdReNaLiN's Avatar
Default Re: Replace or adjust valves?
Just needs adjustment I think.
Old Oct 13, 2010 | 06:27 PM
minilogoguy18's Avatar
Check the valves and adjust if necesarry, these motors also naturally have some chatter to them. As far as oil, well that is a whole different topic, I would always use manufacturers recommended weight which is 5w-30 or something of a wider viscosity range for best lubrication and protection.
Old Oct 14, 2010 | 08:23 PM
SkylineKin's Avatar
I thought that noise was a tell-tale sign of an auto-tensioner going bad. If you had a bent valve it probably wouldn't be running.
Old Oct 14, 2010 | 08:35 PM
serjey15's Avatar
Spin your crank with a wrench, See if there is any "tight" spots where the valve might be touching the piston
Old Oct 14, 2010 | 08:50 PM
JUNlemonPrelude's Avatar
valve adjustment. When adjusting your valves make sure your engine is cold or air temp. use a feeler gauge and specs for your model.
rondogg779
Oct 28, 2019 11:19 PM
02_Si_FTW
Jul 8, 2008 08:06 PM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
Lowez
May 19, 2002 04:00 PM
