Need vacume line help please
93 prelude.
Engine f20b dohc but has obd1 h22 throttle body and intake manifold.
has fast idle valve
iacv
short ram intake so all the factory air box stuff is gone.
no egr valve.
still have iabs
So obviously its kind of a cluster, original owner did the swap and removed items.
So im trying to figure out the correct routing and find out what can be bypassed.
If anyone has pictures of their setup, or can word the correct way to route said items, it would be greatly aprpreciated thanks.
has fast idle valve
iacv
no egr valve.
still have iabs
Re: Need vacume line help please
Really? nice contribution there. If you took the time to correct my incorrect spelling, then you obviously understood what i was asking for. Yet you still took the time to correct it instead of actually being helpful in the manor asked.
Not new to honda-tech. More so inquiring if folks have a similar setup and what they did with their routing. I have ran mine the best i could to factory diagram specs, but obviously with missing items i had to cap off some stuff. After this their still feels like a (vacuum) problem.
it just has fast idle not idle roll? you probably just need to adjust the screw in the throttle body in the center above where the intake tube slips on.
AztecEGhatch
17
12-23-2011 03:14 PM
