wont start
Old Oct 3, 2010 | 09:17 AM
aarongs's Avatar
Default wont start
hi peeps i done a stupid thing a painted my rocker cover on prelude 95 and i put it back togeather and it wont start ???? also i rounded two of the rocker cover nuts so would that be why it wont start ? but it sounds like the spark plugs not fireing to me can any one help??????? thanks aaron.
Old Oct 5, 2010 | 07:08 AM
JUNlemonPrelude's Avatar
Default Re: wont start
Work your way backwards on what you removed, unhooked. When you say rocker cover, you mean the valve cover?
Old Oct 5, 2010 | 09:43 AM
aarongs's Avatar
yea i have done all that about 5 times lol but still no spark
Old Oct 5, 2010 | 10:07 AM
lsjon's Avatar
Check the grounding wire?
Old Oct 5, 2010 | 01:47 PM
aarongs's Avatar
is that the little wire that sits on the side of the rocker cover (vale cover ) cos i took it off to paint it but i scratched the paint off where the wire sits im just running out of ideas and i dont no what i done wrong lol thanks
Old Oct 5, 2010 | 01:48 PM
singlecamslamed's Avatar
Stage 3 CLINGER!
Don't mean to be rude but your typing skills is making me lol.
Old Oct 5, 2010 | 01:59 PM
aarongs's Avatar
haha lol
Old Oct 5, 2010 | 09:29 PM
check fuel pump to see if its priming, fuel pressure regulator? look for all disconnected plugs? try spraying some carb cleaner in the throttle body while someone else starts it up.
Old Oct 6, 2010 | 12:23 AM
ken_464r's Avatar
okay this is kind of a dumb question but are the spark plug wires where there supposed to go? there all different lengths so i would assume so. but just in case lol
Old Oct 6, 2010 | 02:21 AM
aarongs's Avatar
yea i have done that a looked it over about 3 times i looked at the main rely but it looks a bit brown around the joints but could not see any cracks how many clicks should it make just the one
Old Oct 6, 2010 | 09:43 AM
lsjon's Avatar
I can't think of anything else that you would have touched to get the valve cover off. I went through the steps in my head and even the honda technical guide, but outside of the ground wire and plug wires being in the wrong order i can't think of what would be stopping the engine from starting.
34 4321 is the wire orders, if you wanna double check.
12
Old Oct 6, 2010 | 08:32 PM
Heres a simply test to see if you have spark to each cylinder or from the coil to the distributor. Remove one spark plug wire and start your car. If you see sparks/voltage come out the wire, then it should be working properly. Take the ignition coil wire and do the same. No voltage or spark?
Old Oct 7, 2010 | 12:22 PM
aarongs's Avatar
well i no there is no spark going to the ht leads but i aint looked at the ignition coil where is that is it by the dizzy cap i suppose ? thanks
Old Oct 7, 2010 | 12:23 PM
aarongs's Avatar
i think its the ground wire but i sanded the area of the vale cover but still no luck
Old Oct 7, 2010 | 10:16 PM
ignition coil is by the dist. it should go ignition coil, and a wire to the bottom of distributor cap. pull that off where it is connected to the distributor cap. and check for voltage/spark
Old Oct 7, 2010 | 10:33 PM
also have you tried using your service connector to see if you have a DTC, Diagnostic Trouble Code?
Old Oct 7, 2010 | 10:36 PM
One last thing, did you remove or disconnect the ground wire near or on the thermostat housing? its really close to the distributor.
Old Oct 8, 2010 | 12:07 PM
aarongs's Avatar
yea i did remove that why is that a problem ? thanks for your help so far
Old Oct 8, 2010 | 12:37 PM
TurboBB2's Avatar
Why would you touch that to remove a valve cover?
Old Oct 8, 2010 | 10:14 PM
that ground wire is probably your problem for it not starting. It is a critical ground wire.
Old Oct 9, 2010 | 02:38 AM
aarongs's Avatar
yea it is i tryed to put in a diffrent place but still no luck the only other thing i can think of doin is to sand the whole vale cover down again as i sprayed it red and that must be stopping the spark some how
Old Oct 10, 2010 | 11:04 PM
@aarongs what happen now? did you get clean that ground wire and install it in the original location?
Old Oct 11, 2010 | 03:43 PM
aarongs's Avatar
i aint had chance yet but my mate is poping round mine tomo with some jump leads and a amp meter so hopfully i will get her running
wtfbrok3n
Jul 19, 2009 09:45 PM
Japanman2009
Oct 6, 2008 03:15 PM
DougNuts
Jun 26, 2005 02:50 PM
InFaMoUs GsR
Aug 2, 2003 10:49 AM
hybrider
Mar 24, 2002 10:32 PM
